Rear Seat Removal
Old Nov 22, 2011 | 10:50 AM
Carbon Fiber Element's Avatar
CF God
Rear Seat Removal
Hey guys...Need a little help here. Not for me but for a friend. We're trying to pull out the plastics in the center of the rear seat in the coupe. Assuming the whole seat needs to come out but the only diy he got sucks. Im sure soemone has done it so any help would be greatly appreciated.
Thanx,
Tony
Old Nov 22, 2011 | 11:32 AM
Modme's Avatar
Modme
Pull out the entire seat first. There are two clips, one under each seat. Pull up from the middle of each seat to unclip.
Old Nov 22, 2011 | 11:37 AM
ECain18's Avatar
ECain18
^^ what he said
Old Nov 22, 2011 | 11:40 AM
pauliewalnutzz's Avatar
pauliewalnutzz
When your pulling the bottem seat up you need lots of strength and brace yourself because when the seat finally popped up i banged my head on the headliner because you need a lot of force to pull it up
Old Nov 25, 2011 | 12:33 AM
handleandrew's Avatar
handleandrew
you need to put each hand in the center of each seat, fingers towards the floor, palms on the crown of the seat front and then push back and pull up at the same time. the whole bench will unhook and pull out.
Old Nov 26, 2011 | 03:27 PM
CF God
Thanx guys!!! Job done!
Old Mar 19, 2014 | 03:12 PM
SkylineG's Avatar
SkylineG
I will have to do this as well. Need to fit 3 tires at the back. Thanks.
Old Mar 19, 2014 | 07:27 PM
Darth Kinetic's Avatar
Darth Kinetic
pics of the latches, anyone? a visual always helps the mind see what you are doing blind
superjoey
31
Mar 22, 2023 11:56 PM
Doug Crawford
Aug 8, 2015 02:08 AM
