BTAero G37 Sedan Roof Spoiler (ABS) ** $99.00 Shipped **
Old Aug 19, 2011 | 03:27 PM
  #31
ScuderiaFan's Avatar
ScuderiaFan
Originally Posted by RAVSPEC
This is the first I heard of the problem. Wondering did ur painter put in extra primers ? Also moving the spoiler a little down should fix it.
You must have some good hearing to hear noises like this !!!!
Hahaha... yeah I am very particular about stuff like that. Well, I removed the spoiler and the double sided tape; will reapply tape and try to move it down so it doesnt touch the roof.
Question, what double sided tape was on it before? Need to make sure that whatever I get is the same thickness.
Thanks.
Old Aug 19, 2011 | 04:35 PM
  #32
RAVSPEC's Avatar
RAVSPEC
just standard 3M is fine ... no particular !
Old Aug 23, 2011 | 06:00 PM
  #33
ScuderiaFan
Ok so I removed the old tape which was more difficult than i though, cleaned it up and added new 3M 1/2 inch tape. When I put it on the car on Saturday everything went fine; I moved it down a little so there was a gap between the spoiler and the roof and spoiler and the quarter panel. But on Monday, after the car sat outside for about an hour in the sun, it appears that the spoiler expanded. What I mean by expanded is that it was rubbing on the driver side quarter panel which it wasnt when I installed it and I guess because of the heat the spoiler popped off the glass so the tape didnt hold. But when I tried to push the spoiler back down it wouldnt as it was hitting the quarter panel. So now I dont know how to put it back so that it doesnt rub or unstick because its hot outside. And that is what must have happened the first time I installed it because I didnt hear it rubbing but after it sat outside for a little thats when I heard it. So my question is, why does the spoiler expand in the heat?
Old Aug 23, 2011 | 08:00 PM
  #34
RAVSPEC's Avatar
RAVSPEC
Everything expand in heat, but not to a point where it will create any problem.
Did u clean both surface using alcohol ? Did u use 3M double sided tapes ?
Old Aug 23, 2011 | 11:41 PM
  #35
ScuderiaFan
Yep cleaned everything very good with alcohol and used 3M double sided tape.
Are the holes on the bottom of the spoiler there for a purpose?
Old Aug 26, 2011 | 11:59 PM
  #36
CarbonFG's Avatar
CarbonFG
fit 2008 g35 sedan?
Old Aug 27, 2011 | 12:13 AM
  #37
RAVSPEC's Avatar
RAVSPEC
Yes 2007-2011 G sedan.
Old Oct 4, 2011 | 11:54 AM
  #38
FormulaG37's Avatar
FormulaG37
Ordered mine on SUNDAY and got it on TUESDAY. Whoa. I'll post pics soon.
Old Oct 4, 2011 | 12:08 PM
  #39
RAVSPEC's Avatar
RAVSPEC
Still have more
Old Nov 10, 2011 | 01:06 AM
  #40
RAVSPEC's Avatar
RAVSPEC
More roof spoiler just arrived
b2autodesigns
Brakes/Suspension
128
Mar 24, 2018 07:44 PM
BANNISTER
Dec 10, 2015 04:14 PM
drewfinity
Aug 20, 2015 08:17 PM
