Exhaust restriction? 2.5" cats to 2.25" catback
Old Nov 3, 2020 | 07:39 PM
Dzionassi's Avatar
Dzionassi
Originally Posted by backman_66
Even though I'm not running e85, my injector duty cycle was hitting 95% and I even saw 97-98% a few times in the upper rpm's so I really think I'm putting down some good numbers to need that much fueling.. most people say that with those mods, injectors aren't needed, but I needed them!
And Eugene, my tuner, said from looking at some of the data that im definitely north of 320whp but of course, I haven't dyno'd it yet.
I was hitting 99% at few places too, usually up to 95%, but according my tuner I dont have to touch injectors, unless i will go corn fuel.
Old Nov 6, 2020 | 12:34 PM
backman_66's Avatar
backman_66
I guess it's not absolutely essential to get injectors but after doing quite a bit of research on duty cycle, pulse widths etc. it really isn't good to let your injectors work that hard. At 90%+ duty cycle, the injectors don't really have the proper amount of time to "rest" between cycles and you're going to get inconsistent amounts of fuel which will affect proper atomization and combustion, which will not give you consistent results when tuning. I felt that for a relatively low cost to upgrade, it's well worth the price to be running more consistently for the rest of the life of my car which still only has 43k miles.
I don't really understand why a tuner would say you don't need injectors when seeing duty cycle numbers that high.. BUT I'm not a tuner, just a self-educated researcher based upon stuff on the internet, so.... lol
Old Nov 6, 2020 | 11:00 PM
PNW_IPL's Avatar
PNW_IPL
98% with 550cc?
Old Nov 6, 2020 | 11:09 PM
backman_66's Avatar
backman_66
Originally Posted by PNW_IPL
98% with 550cc?
sorry, I meant when I had stock 380cc
Old Nov 6, 2020 | 11:10 PM
PNW_IPL's Avatar
PNW_IPL
Good lol.
I was hitting 107 with oem 330cc and am upgrading asap
08 vq35hr
Old Nov 16, 2020 | 02:14 PM
projectpanda13's Avatar
projectpanda13
I have more than just "basic" i/e...
I have 2.75" intakes with upgraded bellmouth + velocity stack in the end (z1's upgraded filters dyno'd 5whp i think? just as an example)
ported tb's, upper, AND lower manifold
GTR 550cc injectors
Rhfc and catback
ecutek tuned and higher octane fuel
RWD and 6MT
I thought in my original post I mentioned my mods but sorry if I wasn't clear on that
Glad those ported manifolds are working well for ya. Also seems like you'll be making more power than when I had them. Definitely interested in your numbers when you get to hit the dyno.
Old Nov 16, 2020 | 02:37 PM
backman_66's Avatar
backman_66
Thanks man! But I just don't know about my power numbers now.
I feel like my exhaust is really holding me back now since it's 2.25" and the Q300 has those chambered mufflers too.. hmm.
Old Nov 18, 2020 | 08:07 AM
RMB5190's Avatar
RMB5190
Doubtful.
Old Nov 18, 2020 | 08:11 AM
projectpanda13
I switched from a Top Speed exhaust (2.375") with Motordyne y pipe to a full Motordyne exhaust and didn't notice anything different. I had the car dynoed on a different dyno but the numbers matched up.
However, since I've switched to single exit, i noticed more pick up in mid range, i haven't dynoed this setup yet.
Old Nov 18, 2020 | 09:15 AM
backman_66's Avatar
backman_66
I'm just basing it off the charts you can find online about how much HP a 2.25" exhaust can support before becoming a point of restriction. For mild NA G's it shouldn't be a problem, but in my case I would say it's a restriction.
https://m.roadkillcustoms.com/determ...t-tubing-size/
Old Nov 18, 2020 | 09:59 AM
3.7 liters is 225 ci, and according to that chart recommended tubing size for a dual exhaust is 2.0 to 2.5". Even if you had a larger engine with 350 BHP, the chart still says 2.5" dual pipes is recommended.
Originally Posted by RMB5190
Doubtful.
Agreed. But the OP really wants to upgrade. And it reads like he's going to convince himself it's necessary, whether it is or isn't.
15jeffreyr
Dec 10, 2015 10:55 AM
jsampsell
Nov 2, 2014 10:54 PM
surfwagon
Intake and Exhaust
Dec 21, 2012 08:04 PM
glive
Intake and Exhaust
Dec 8, 2012 07:20 PM
Crespo
Sep 11, 2012 08:39 PM
