Help Motordyne Resonated XYZ Pipe
Old Nov 28, 2019 | 11:52 PM
steveng37's Avatar
steveng37
Currently I have a top speed muffler delete on my sedan. It may sound stupid, but would adding the resonated y pipe help with drone? I've gotten used to the drone, and there seems to be less now, but at some points it can be annoying. Obviously the easy answers are; put the stock mufflers back on, or buy a full catback. I'd like to utilize what I have now, and I cannot afford, nor want to spend 1500-2000 on an exhaust. I can get the motordyne y pipe for in the high $300 range.
Old Nov 29, 2019 | 10:44 AM
PNW_IPL's Avatar
PNW_IPL
Yes it will help.
I have a feeling if you are buying new, the motordyne is closer to 500 with the resonator module.
Check out circuit werks resonated Y pipe on ebay. About 260 on ebay. says for 350z but Y pipes are interchangeable.
so long as RWD.
I've used it in the past with good results on drone/ high pitch noise cancellations.
Old Nov 29, 2019 | 10:56 AM
steveng37's Avatar
steveng37
I should mention I am AWD. I called motordyne, and the AWD XYZ pipe is $414. That is before 10% off for black friday. I will reach out to circuit werks and see if they have anything for AWD
Old Nov 29, 2019 | 10:57 AM
PNW_IPL's Avatar
PNW_IPL
XYZ doesn't include the module I believe. Double check. I believe it's a separate cost.
Old Nov 29, 2019 | 11:11 AM
steveng37's Avatar
steveng37
Just double checked. AWD Resonated XYZ Pipe for $373 after discounts, with no lead time. They figure $60-$70 shipped. So call it $450 out the door.
I looked at the circuit werks y pipe, and the listing for the G35 says it will fit all models. Would it fit AWD since it's more of a U shape and not a V shape, to clear the transfer case?
Old Dec 18, 2019 | 07:07 AM
Fernando Moreno's Avatar
Fernando Moreno
Originally Posted by PNW_IPL
Yes it will help.
so long as RWD.
Wait so the y pipe for the 350z could fit on a 370z/g37? Is that correct? I’m looking for one too but don’t want to spend almost 600 on that if there’s cheaper ones that do about the same
Old Dec 18, 2019 | 07:59 AM
PNW_IPL's Avatar
PNW_IPL
Yes interchangeable
cshel777
Jul 19, 2019 07:58 AM
markvaughan92
Apr 25, 2019 03:55 PM
Daddy Fat Sacs
Jan 11, 2018 02:39 PM
ECain18
Jan 14, 2013 12:51 PM
