Flex Pipe removal/replacement
Old Oct 4, 2019 | 06:38 AM
JoeDirrtyy's Avatar
JoeDirrtyy
I want to know if it is possible to cut out and remove the flex pipes on my Megan racing Y-pipe, and replace them with resonators without any issues of anything cracking or being damaged.
Old Oct 4, 2019 | 08:11 AM
RMB5190's Avatar
RMB5190
Go for it.
Old Oct 4, 2019 | 09:33 AM
JoeDirrtyy's Avatar
JoeDirrtyy
That doesn’t really give me any explanation. It’s it okay to run without flex pipes?
Old Oct 4, 2019 | 10:03 AM
Baadnewsburr's Avatar
Baadnewsburr
Post
for real?
Old Oct 4, 2019 | 10:20 AM
JoeDirrtyy's Avatar
JoeDirrtyy
Thanks bro! You were a big help!
Old Oct 4, 2019 | 10:42 AM
OldG2NewG's Avatar
OldG2NewG
It's not a good idea to remove the flex pipe. The exhaust system needs to be able to flex as the engine shifts and moves.
Old Oct 5, 2019 | 07:51 AM
RMB5190's Avatar
RMB5190
Nothing is going to crack or get damaged...it's a steel system with integrated rubber hangers...As the engine moves so does the exhaust via the hangers. Still doesn't matter, virtually every after market piece you see is a solid system. Take a quick look at the design of the top three rated aftermarket systems for the G37.....
Old Oct 5, 2019 | 12:14 PM
JoeDirrtyy's Avatar
JoeDirrtyy
I’m getting some pretty mixed opinions here.
Old Oct 5, 2019 | 03:28 PM
latino914's Avatar
latino914
Not a good idea! Leave the flex section alone
Old Oct 5, 2019 | 04:05 PM
RMB5190's Avatar
RMB5190
Fast intentions: deleted flex section, Ark: Deleted flex section. I myself have deleted said flex section..zero issues.
Go for it.
Old Oct 8, 2019 | 02:11 PM
Surfnazi's Avatar
Surfnazi
Better built exhaust systems dont use flex pipe since fitment is spot on
Old Oct 8, 2019 | 04:49 PM
projectpanda13's Avatar
projectpanda13
I replaced my flex sections with pipes on my Motordyne exhaust. No problems so far. If anything, it gave me more ground clearance with the center muffler.
PinnacleG37
Intake and Exhaust
Jul 11, 2019 02:12 AM
tscani
Jul 29, 2016 12:53 PM
bsettles
Apr 30, 2015 11:33 AM
JakeB
Intake and Exhaust
Oct 15, 2013 04:49 PM
911turbo
Intake and Exhaust
Nov 24, 2009 11:52 AM
