Need advice on aftermarket resonator for drone
Old Mar 4, 2018 | 06:20 AM
afrayedknot's Avatar
afrayedknot
I have a g37x sedan with a muffler delete and 2.5" pipe from stock resonators. Right now there is an excessive amount of drone at 1500-2000 rpm. I want to find a way to minimize this with the addition of resonators. I was thinking of replacing the stock resonators with 12" Vibrant 1790 or possibly the Vibrant 1141 ultra quiet resonator. Will this make a big impact on lowering the drone? Or is there a much better alternative that I am not aware of?
Thanks for any input.
Old Mar 4, 2018 | 11:03 AM
guy from norcal's Avatar
guy from norcal
I would try the ultra quiet resonator. Or maybe this
I have read on several mustang and pontiac forums that guys have used the helmholtz resonators with good results.
Old Mar 5, 2018 | 10:18 AM
afrayedknot
I think I'm going to go with the ultra quiets. I've seen your videos when you were running the 1794s with muffler delete, and it was a bit loud for me.
The helmholtz/j-pipes are a really interesting solution that I considered, but I feel like I should get the deepness in the exhaust tone I want first, before I start eliminating the drone. My hope is that I will be able to deepen the tone while also eliminating some drone with the vibrant ultra quiet resonators.
My concern now is whether I should use the same size in/out diameter of the oem resonator (2.25") or match the new 2.5" pipe when I install the vibrant ultra quiet. It seems that the difference would be whether the flow of air travels from 2.25" to 2.5" before or after the resonator.
Logically, I would think that the 2.5" in/out would be better because the exhaust flows in at 2.5" and exits at 2.5", whereas if I used 2.25" the flow of air would be slightly altered as the piping increased to 2.5". Am I correct that the change in the diameter of the in/out will change the pressure within the resonator? If so, that would lead me to think that 2.5" from the Y-pipes to 2.5" out to mid pipe should be the better option.
Old Aug 4, 2018 | 01:07 PM
sidestepca's Avatar
sidestepca
You ever figure out if 2.25' to a 2.5 is okay? also how is it sounding my 1790's are on the way and im getting them welded in with a muffler delete
Old Aug 23, 2018 | 09:38 AM
afrayedknot
I actually haven't made any changes to the exhaust yet. I am, and have been, vacillating between going the custom or aftermarket route. However, if I decided to continue customizing the exhaust I have now, I would swap the oem resonators with a pair of 2.5" vibrant 1794 resonators. Otherwise I am going to try and find a used ARK grip.
Slayer7435
Intake and Exhaust
Jul 15, 2015 02:30 AM
beers64
Apr 27, 2015 08:56 AM
Nflder
Intake and Exhaust
Mar 14, 2015 05:28 PM
GianG37x
MODDING 411
18
Sep 3, 2011 01:16 PM
