Hfc & y pipe
Old Sep 30, 2017 | 08:47 PM
bassy's Avatar
bassy
Hfc & y pipe
I currently have the Tanabe axle back and Tanabe mid pipe on my awd coupe. I need to replace the cat converter and y pipe. I am debating on the Berk HFC and Megan Racing Y pipe. The Berk HFCs seem to have positive reviews. I couldn't find many reviews on Megan Racing Y pipe, however. How is MR as a brand in terms of quality? Because my car is an awd, I have so few choices for Y pipes. What other companies make Y pipes for awd coupes that I should check out? Thanks for any suggestions.
Old Oct 2, 2017 | 10:12 PM
Dzionassi's Avatar
Dzionassi
Berk hfc+aftermarket y pipe= rasp!!!!
Old Oct 2, 2017 | 10:42 PM
If you get HFCs I'd strongly consider resonated veraions to avoid what Dzionassi is describing, and mismatched piping at the HFC to Y-pipe connections are also rasp inducers.
Old Oct 3, 2017 | 06:14 PM
kroy's Avatar
kroy
Megan is built in Asia. I heard some say Megan is built in Taiwan so a little better quality than China made. But I've also heard a lot of people say Megan is also cheaply built.
FI RHFC does minimize most the rasp/hiss. I can only hear that hiss when standing outside of the car.
Old Oct 3, 2017 | 11:04 PM
Dzionassi's Avatar
Dzionassi
I have zero rasp, but i had to add 3 resonators and smaller flex...
Old Oct 4, 2017 | 11:51 AM
bassy's Avatar
bassy
Dzionassi: what kind of setup do you have there? I recognize the Tanabe midpipe because I have the same one. But it looks like you did some custom fabrication on it. Your Y pipe looks beefy also. Your setup may even fit my car. Do you have any video or sound clip of your exhaust?
Brad: I didn't realize that the Berk HFCs are not resonated. I already bought them and they're being shipped now. I only found out about the Fast Intentions RHFC recently (after when I'd already ordered the Berk).
Kroy: A coworker of mine has Berk HFC and Ark setup and I didn't hear any rasp. Some people say there's rasp, but he disagreed. I just came across Meisterschaft Y pipe after doing some more research, but that thing is expensive (compared to the cheapo Megan Racing one). I'm sure the quality of the Meisterschaft one is way better. I'm not sure if it will fit my car or reduce/eliminate the potential raspiness. I guess I'll find out how the MR one works out first and go from there.
Old Oct 4, 2017 | 12:55 PM
Dzionassi's Avatar
Dzionassi
[QUOTE=bassy;4161274]Dzionassi: what kind of setup do you have there? I recognize the Tanabe midpipe because I have the same one. But it looks like you did some custom fabrication on it. Your Y pipe looks beefy also. Your setup may even fit my car. Do you have any video or sound clip of your exhaust?
Yes, this is Tanabe midpipe with Agency Power Y pipe ( wanted to match my berks 2.5 hfc). I removed center flange and welded in Vibrant 1142 3" Ultra Quiet Resonator + two more Vibrant 1792 Bottle Style Resonators in place of flex and installed much smaller flex....
I will try to get you sound clip later. i am running stock axle back right now, because tanabes gives me to much drone.
I guess will be working Helmholtz resonators
Old Oct 4, 2017 | 01:43 PM
kroy's Avatar
kroy
Dzionassi, how much does all this custom work cost? Just seems like you've done a lot.
Old Oct 4, 2017 | 01:57 PM
Dzionassi's Avatar
Dzionassi
resonators $160+(2x$25 for flex) and whatever welder charges...$200-$300
Old Oct 10, 2017 | 09:15 AM
Eyeshield25's Avatar
Eyeshield25
I was thinking of doing Z1 hfc and XYZ motordyne Y-pipe with resonator
Old Oct 10, 2017 | 10:09 AM
That would be a nice way to go ^^^
Old Oct 10, 2017 | 04:24 PM
Dzionassi's Avatar
Dzionassi
XYZ motordyne is for manual only. Isn't it?
Old Oct 10, 2017 | 10:16 PM
Ricio1991's Avatar
Ricio1991
No I have a 7 speed auto it doesn’t matter what transmission you have
Old Oct 10, 2017 | 10:24 PM
KAHBOOM's Avatar
KAHBOOM
Super Moderator of Pwnage
I second that thought. Motordyne XYZ is nice. I have FI RHFC and Motordyne XYZ with straight pipe... no rasp.
I also have the XYZ with resonator that I had on in combination with a Sport Muffler. Both provided a nice sound.
Old Oct 10, 2017 | 10:32 PM
Dzionassi's Avatar
Dzionassi
Is it AWD?
