Looking for suggestions on intake
Old Aug 23, 2017 | 12:42 AM
Yusephi's Avatar
Yusephi
Hello all, new here and to the scene in general. I own a 2012 G37X and have been thinking of doing some simple modifications to the car. The first thing i planned on doing was the intake and was hoping some of you with more knowledge than me could offer some suggestions? Thank you in advance! Edit: I suppose a budget might help. I'm looking to spend at the most around 300$, something in the 170-250$ range would be best.
Old Aug 23, 2017 | 06:23 AM
Landshark's Avatar
Landshark
unless you're looking to spend a couple hundred dollars for sucking noises, i wouldn't bother.
if you are going full bolt-on mods and a tune, sure, but with air intake alone you aren't going to gain any kind of extra power you'd notice (possibly even lose some low-end torque), and removing/cleaning the filters will be a PITA.
get some non-oiled drop-in filters for the stock intake - they are stupid-easy to remove and replace.
Old Aug 23, 2017 | 09:46 AM
RMB5190's Avatar
RMB5190
Remove the sound dampeners and replace stock filters with K&N filters. Get all the sucky sound and dyno proven 10 WHP. Spend the rest of the cash on a S model rear sway
Old Aug 23, 2017 | 12:54 PM
kroy's Avatar
kroy
1. K&N drop in filters. easiest. will be direct replacement for your current filter. use same stock air box. no change in sound. slight performance gain.
2. any short ram intake. people call it a hot air intake because filter is right by all the heat sources. hot air = less power. arguably you will decrease your horsepower on a hot day. go this route for the sound.
3. takeda/stillen long pipe cai. this is real power gain. still not much though, so if you're expecting more than a couple of horsies, you will be disappointed. requires cutting a hole to create a vent for filter.
4. r2c paper filter. it's basically a short ram with a little bit better heat shield. it is also a paper filter. One of the more popular options here because it looks cool and sounds cool. And people some people prefer to go with paper filter.
overall, you're talking like 2-4hp difference no matter which direction you go.
Old Aug 23, 2017 | 03:21 PM
Yusephi's Avatar
Yusephi
Thank you guys for those suggestions!
Old Aug 23, 2017 | 04:25 PM
Welcome to the site! Good replies above, if you do decide on a short ram or cold air intake check our private classified folder might find one for a much better price.
Old Aug 23, 2017 | 08:09 PM
saywat?'s Avatar
saywat?
saw a guy install a ca intake from ebay. didnt seem all that bad
Old Aug 24, 2017 | 12:16 AM
MerakiAutoworks's Avatar
MerakiAutoworks
Your #1 Infiniti Vendor!
Takeda intake!
-Josh
Old Aug 24, 2017 | 07:53 AM
Landshark's Avatar
Landshark
i went with R2C Black Hex non-oiled drop ins. don't need to buy a cleaning and oiling kit - blow them clean with an air compressor ... if they're really dirty, use water.
also no chance of fouling the MAF sensor with over-oiling.
Old Aug 24, 2017 | 11:05 AM
maGorheadrush's Avatar
maGorheadrush
I went with the R2C SR intakes. Power increase is minimal especially without a tune in my experience. But holy ****, their sound and appearance make them totally worth it
Old Aug 24, 2017 | 02:22 PM
micafd3s's Avatar
micafd3s
got a part number?
Old Aug 25, 2017 | 06:31 AM
The Pope's Avatar
The Pope
I went with the UPGR8 Drop-In Non-Oiled Filters.
I believe the p/n is "U8701-3004" but you should verify this before ordering.
Old Aug 26, 2017 | 05:26 AM
Landshark's Avatar
Landshark
Originally Posted by micafd3s
got a part number?
R2C PF10544 Black Hex drop in filter
R2C PF10544 Black Hex replacement filter - 07+ Infiniti G35s/G37
if i remember right, that price is for 1, and you''ll need 2. i'd double-check before ordering ....
Old Aug 30, 2017 | 01:06 AM
Yellafella's Avatar
Yellafella
K&N drop ins if you're on a budget and save up for 3" Admintuning intakes or AAM r line intakes. But then again Stillen gen3s used have been floating around in the low $300 range in both our classifieds and the370z classifieds.
Old Aug 30, 2017 | 12:56 PM
Surfnazi's Avatar
Surfnazi
I have the fortuneate abiility to have 2 coupes same year one has drop in kn filters with silicone intake pipes and other had kn intake kit they are the same on output just sound is louder with full intake
