Made the demon bolts my be-atch :)
Old Apr 21, 2016 | 12:37 AM
  #46
PNW_IPL's Avatar
PNW_IPL
I used some leftover Valvoline Max Life (Nissan Matic S compatible) in the red jug. I'd imagine most any ATF will suffice when mixed w/ Acetone. I used Acetone from my wife's bottle that she got at Sallys Beauty supply for nail polish removal.
Thank you sir!!
Old May 8, 2016 | 02:22 AM
  #47
PNW_IPL's Avatar
PNW_IPL
How long should i let the 50 50 mix sit on the o2 sensors? Dont want to damage them but they are also rusty as fk
Old May 8, 2016 | 03:05 AM
  #48
PNW_IPL's Avatar
PNW_IPL
Got the o2 sensors out without incident 18in breaker bar. Got the cat to tranny brace bolts off and cat to y pipe bolts off. Going to let the 6 total 3 ea side cat to header bolts set over night.
Old May 8, 2016 | 08:17 AM
  #49
Glad to hear you're well on your way. G/L w/ the demons
Old May 8, 2016 | 09:51 AM
  #50
lobuzz311's Avatar
lobuzz311
I was able to get the demon bolts off without any penetrating fluid. I couldn't figure out how to get the can of PB down there to spray. 24" breaker bar was enough to snap the bolts in half.
Made the demon bolts my be-atch :)-h9wrb5jh.jpg
For the four lower bolts, I soaked in PB for 20 minutes or so. This was much easier because I had the car on a lift. Same breaker bar broke them free without any issues.
Old May 8, 2016 | 07:45 PM
  #51
If I were to do it again on another G/Z I'd use a syringe, that ATF/Acetone Mix works the best but hard to isolate it to just the bolts when using a spray bottle.
Old May 8, 2016 | 08:43 PM
  #52
PNW_IPL's Avatar
PNW_IPL
Finished.
5 hrs start to finish.
Hardest bolt was driver side bottom due to space. Very cramped.
Thanks to all you for the help.
Much appreciated .
Do i need to reset ecu or leave it?
Car pulls very hard now as is
Old May 8, 2016 | 10:36 PM
  #53
No need to reset ECU, it may help short term but overall not really a big deal.
Glad you made the demon bolts your be-atch too!
Old May 8, 2016 | 11:14 PM
  #54
PNW_IPL's Avatar
PNW_IPL
Awesome. Thanks again for the tips!
Old Jul 20, 2017 | 01:47 PM
  #55
G37_4DR's Avatar
G37_4DR
Sorry to resurrect an old thread like raising Lazarus from the dead, but thanks for the guidance, Brad. I feel fortunate that living in Arizona with an AZ car, I didn't have any rust to contend with. PB Blaster soaking overnight worked for me and although I bought one, I ended up not needing the universal impact joint. 1/2" breaker bar with jack handle slipped over it + a 12", 10", and 6" extension. Took both bolts downtown to Chinatown.
Old Jul 20, 2017 | 03:30 PM
  #56
Nice! ^^^^ There is something to be said for "it's a dry heat"
Old Aug 21, 2017 | 11:24 AM
  #57
G37_4DR's Avatar
G37_4DR
So quick update on my experience. Back on 7/20 (see my post above blnewt's), I had some spare time and some motivation, I decided to just try and loosen the demon bolts on my car. My FI RHFCs weren't scheduled to be shipped for another month, but I figured it couldn't hurt to at least loosen the demon bolts in the meantime. With a lot of effort and a jack handle on the end of a breaker bar, and pushing my body weight into the tool to ensure the socket remained evenly seated on the bolt head, they finally gave way.
Fast forward and yesterday I removed my cats ahead of my RHFCs arriving tomorrow. I thought the hardest part was over now that the demon bolts were at least broken free. Well, they were almost as hard to turn as back in July and I ended up snapping both of them. I'm not sure how that happened. I definitely felt them break loose back in July and yesterday it felt like I was doing the job almost all over again.
What tool or remedy kit do I need to buy in order to be able to back that broken bolt shaft out of each flange?
Old Aug 21, 2017 | 09:47 PM
  #58
Sorry to hear of that, bolts should only be used once, and when new ones are installed you should use copper-based anti seize on the bolts. Once you tightened them back up and high heat is applied combined w/ condensation you get another rust bomb to try and break free
Probably need to have them drilled out now or maybe a torch w/a lock wrench perhaps???
Old Aug 21, 2017 | 09:54 PM
  #59
G37_4DR's Avatar
G37_4DR
Sorry if I wasn't clear; definitely did not re-use these bolts. I had simply broken them loose back in July, then left them that way (mostly-tight). Then came back a month later and tried to loosen them all the way and they snapped.
Old Aug 21, 2017 | 11:15 PM
  #60
Oh, yeah, that's a bad situation but quite a few around here have had to go to the nuclear option aka the torch. G/L hope it doesn't set you back much.
