Takeda cold air intake
Old Oct 16, 2015 | 11:01 AM
  #31
Ryne's Avatar
Ryne
The Steering Wheel Guy
Originally Posted by Rybitron
Im not trying to be rude, but that isn't true. Even if you slightly deform a circle it has less cross sectional area.
Take a circle with a 4 inch diameter it has a cross sectional area of 12.57
That same circle deformed to an oval shape (3 x 4.88) has the cross sectional area of 11.52, so about 1 square inch less. The more you deform it, the more cross sectional area you will loose.
A circle is a more efficient shape to move air through than an oval or rectangle.
Rybitron is right. Math beats common sense every time. Originally I was thinking of this from a conservation of mass standpoint (the mass being the circumference/perimeter). Well, I was completely ignoring the Geometry of the shape and its corresponding surface area. A circle will have the best efficiency as Rybitron said, essentially a circle has a surface area that is equal to its circumference. When you deform the circle into an ellipse, it maintains its circumference/perimeter (Due to conservation of mass), but the surface area decreases directly with the amount of deformation.
Thanks Rybitron for making me not take the easy way out and apply the science/math.
Old Oct 16, 2015 | 02:14 PM
  #32
User 122320's Avatar
User 122320
Originally Posted by ANMVQ
Not true the bumper doesn't have to come off, that's the Stillen intake only cause you have to trim the rad support. The Takeda you can leave the bumper on. I did only removed the front grill and top sheild
what a hassle. i'll stick with the stock cold air system. Also, wouldn't removing the top shield allow hot engine air to creep into the intake?
So the stock sealed system is a true cold air system.
Also, what do u do when its pouring cats and dog? wouldn't water get into the filters from the grill area? and when u wash ur car? or when someone else washes ur car?
Old Oct 26, 2015 | 11:04 AM
  #33
Ryne's Avatar
Ryne
The radiator cover comes off for installation, but is reinstalled after the tubes are put in. They make a splash shield, but many go without and have no issues. I do not have the shield and have gone through many car washes and downpours, as have many others, without issue.
Old Mar 4, 2016 | 06:46 PM
  #34
salmonslayer's Avatar
salmonslayer
I just installed my Takeda CAI from the group buy. Install was easy and I did take off the bumper. I felt it's a must in order to trim. I had to cut/trim and widen the hole on the passenger side to be able to squeeze in rubber tubing through. The driver's side did not have to, just squeezed it through.
I am working from home today and have not had a chance to go out on a test drive. Am I supposed to unplug the Neg on my battery to reset the computer before I drive?
Old Mar 7, 2016 | 06:33 PM
  #35
ShuuraRG's Avatar
ShuuraRG
I didn't experience any issues with the passenger side. For me, the drivers side gave some concerns. However, I didn't expect the performance experienced afterwards. The Takeda along with my FI CBE definitely made a difference.
Old Mar 16, 2016 | 08:01 AM
  #36
ANMVQ's Avatar
ANMVQ
Wait till you change to two single filters and the TB's don't "Fight" for air
Attached Thumbnails Takeda cold air intake-takedatwin.jpg   Takeda cold air intake-takedatwin2.jpg
Old Mar 16, 2016 | 08:38 AM
  #37
ShuuraRG's Avatar
ShuuraRG
Thanks for the advice! Which filters are you using (model #'s)?
Old Mar 16, 2016 | 09:13 AM
  #38
ANMVQ's Avatar
ANMVQ
I used the Spectra filters from Advanced auto and grab the AEM rain shocks from Amazone.
Old Mar 16, 2016 | 09:55 AM
  #39
ShuuraRG's Avatar
ShuuraRG
this video is a tad old, but have you noticed/experienced the same with yours?
Old Mar 16, 2016 | 10:18 AM
  #40
Infinitard's Avatar
Infinitard
Interesting, did you notice any difference in performance after swapping to dual filters?
Old Mar 16, 2016 | 12:16 PM
  #41
chuckie311's Avatar
chuckie311
Drop A Gear and Disappear
if there is a difference very minimal i'm sure your not going to notice it..
Old Mar 16, 2016 | 02:54 PM
  #42
ANMVQ's Avatar
ANMVQ
I felt I hair more response and upper pull but nothing wild, but I do they fight for air, and MY BAD ShuuraRG I used Kn filters
K&N Universal Rubber Filter
Part No RU-2990
Old Mar 18, 2021 | 07:44 PM
  #43
infiniticarplug's Avatar
infiniticarplug
What size filters to get for the replacement to have dual cones fit and not head butt each other? Just did the intake today and not a huge fan of the single filter connection wise.
Coupe_G
Intake and Exhaust
Jul 25, 2017 02:22 PM
Jbunz
Intake and Exhaust
Nov 4, 2016 03:26 AM
PNW_IPL
Jun 16, 2016 09:31 AM
twin_snails
Aug 31, 2014 02:50 PM
fgxmfmq
SouthEast
Jun 17, 2013 06:22 PM
