My next Mod; intake and HFC
Old Sep 14, 2015 | 10:10 AM
VIVID's Avatar
VIVID
Pyroclastic Flow
Any input or consideration of the Injen LT CAI?
I'm installing one of those on Thursday. The opinion being that there was less surgery and a Gt-Spec FSTB would fit nicely.
So this is really a 'reassurance' post on my part. I will, however, post some feedback when I have it done and get a bit of seat time (though there are pages of CAI feedback in the Mod section...many touting the precise CAI that the poster installed)
I do have some pre-reticence though: I think I should have gone black instead of polished. Though Rochester is right; I can have them PCd.
Sean
Old Sep 14, 2015 | 10:21 AM
Shiny bits in the engine bay look like embarrassing crap when neglected. Whereas black components just look dirty. The point being, you'll need to start detailing your engine bay, Sean.
Old Sep 14, 2015 | 02:06 PM
2012G37's Avatar
2012G37
Here's a couple posts on the Takeda (which is what I'd get if I was wanting a true CAI) with tips & pics for a Sedan install. And the whole thread is a good read especially since you have the AWD Sedan
https://www.myg37.com/forums/build-t...ml#post3902079
https://www.myg37.com/forums/build-t...ml#post3903785
Thanks I'll read these. Should have enough time to select either one of them within a month or two...CAT should be ordered by next week. Depending on how I feeling I may order tomorrow. .
Old Sep 14, 2015 | 05:18 PM
conkus805's Avatar
conkus805
Originally Posted by 2012G37
This interesting, gearing, hopefully there haven't been any bad luck
With anyone doing this and has survive over 2yrs...As for the $ range its not too bad, my recent mod was close to 8k. I'll do some research on this too, will it work on a X?
I'm most likely going with Stillen Cai and FI Rhfc.
But I plan on doing the FI Rhfc, just to see how I like that growl and if i need more from the CAI. Thank you all for your opinions and advice. ...
Sorry, I didn't notice you have an x, the gears are out of the question at this time. one person on this forum tried really hard to mod his x with gears but the problem he ran into was the front diff needing to be the same gearing as the rear. I guess the diff housing is too small to fit any other gears besides what it comes with. also, there are no other front diff's nissan makes with the proper gearing.
Old Sep 14, 2015 | 05:23 PM
conkus805's Avatar
conkus805
Sean
injens really prone to hydrolock due to their position, I think I read that some people have had issues in that area. I think as long as your not in an area the sees heavy rainfall, you'll be ok.
Old Sep 14, 2015 | 10:41 PM
VIVID's Avatar
VIVID
Pyroclastic Flow
Thanks conkus.
I got a set of Hydro-shields with the intake. With those and caution during heavy rain I should be okay. If not...a very expensive lesson...and not my first
Sean
Old Sep 14, 2015 | 11:03 PM
2012G37's Avatar
2012G37
Dam, guess i can cross that off my list...
Old Sep 15, 2015 | 07:08 PM
conkus805's Avatar
conkus805
That is a bummer for you x'ers because it would be insane to launch with awd and 3.90's or 4.08 gears.
Old Sep 15, 2015 | 09:46 PM
2012G37's Avatar
2012G37
Almost ordered RHFC today. Shop guy was asking me if i need the extended O2 bungs for driver or passenger. What are these and do I need them?
Old Sep 15, 2015 | 10:42 PM
The RHFCs shouldn't throw a CEL code but the extended pipes makes it even less likely. More of an issue w/ Test pipes.
Old Sep 15, 2015 | 10:44 PM
2012G37's Avatar
2012G37
cool! I'll get both, extra 40 isnt too bad.
Old Sep 15, 2015 | 11:04 PM
I think you're misunderstanding his question because he's misunderstanding what he's asking. I could be wrong, but...
OP, you said up front you were ordering the FI RHFC. The O2 Sensor connectors on those cats are long J-Shaped connectors, designed to pull the sensor out of the stream and spoof the ECU. This is how they come, by default.
For an extra $20 per side, FI will install a second, standard bung connector for use with a wide-band sensor if you were to actively tune the car via onboard software. Unless that's your game, and unless I'm mistaken, you don't need to do this. Doesn't hurt, but doesn't help either.
Brad, re-read what's going on here. Seems like some confusion.
Here's a pic of the FI RHFC's, for perspective:
Old Sep 15, 2015 | 11:13 PM
Thanks for the clarity John, that would seem to be what that add-on option would be.
Old Sep 15, 2015 | 11:15 PM
  #29
2012G37's Avatar
2012G37
So the extra bungs are more for tuning/dyno. And adding them wont make a big difference on CEL.
Old Sep 16, 2015 | 07:53 AM
  #30
Adding them won't make any difference on CEL whatsoever. There is no relationship between one or the other.
It's been my second-hand research (and my personal experience) that FI cats simply don't register out-of-range on the O2 sensors. Part of that has to do with the J-shaped design of their connector. Another is that FI uses a catalytic converter with a 300 cell-count, opposed to the more typical 200 cell-count found in other high-flow cats. In other words, there's more surface area for catalyst to do its job.
By that, you could argue that they are *less* high-flow than other manufacturers, and I suppose that's fair. Similarly, all high-flow cats are *less* high-flow than test-pipes. However, *all* HFC's are also less restrictive than the OEM parts, and there's a point of diminishing return here, where personal choices come into play. Personally, I think FI cats are the perfect compromise between OEM cats and test-pipes, while at the same time being a very high quality build for cats that actually function the way catalytic converters are intended.
The only flaw in FI cats is the lack of support for the retaining bracket. The absence of this connecting bracket creates a noticeable vibration at idle. This is more noticeable on the 6MT, because the engine isn't engaged with the transmission at idle, but it's there nonetheless.
Man, I've taken a brain dump all over your thread, LOL.
