R2C intake
Old Apr 20, 2015 | 06:33 PM
Himalaya's Avatar
Himalaya
R2C intake
I just installed them a few days ago and under 3k Rpms I get sort of a hissing sound from the intakes. Is this hissing from the intakes and is it normal or is it caused from a leak?
Old Apr 21, 2015 | 11:22 AM
pheonix75's Avatar
pheonix75
Mine don't hiss....you can hear a throatier sound of the air intake, even at idle. So I would surmise there may be a leak, I would check all of the hoses to ensure that they are on nice n snug.
Old Apr 21, 2015 | 06:41 PM
MJaga's Avatar
MJaga
Likely a leak. Mine don't hiss either.
Check the connections on the throttle bodies... after several thousand miles mine loosened up and needed to be readjusted (rubber was more pliable after several thousand miles of use, better fitment).
Old Apr 22, 2015 | 03:55 PM
South3rn's Avatar
South3rn
Sounds like a vacuum leak. If you can hear it in the car, should be easy to hear/find it under the hood.
Old May 1, 2015 | 10:15 AM
dmg6768's Avatar
dmg6768
Is it a hiss or a whistle?
Cone filters have a tendency to whistle.
Old May 4, 2015 | 12:02 PM
Eyeshield25's Avatar
Eyeshield25
My R2c doesn't hiss or whistle, it just roar above 5k and and stay normal under that. Hiss is definitely a leak.
Old May 6, 2015 | 06:59 PM
beachbum718's Avatar
beachbum718
I installed mine and now my service engine light came on.I disconnected battery to see if ecu would relearn it.3 days ago and now after a long drive.it's on again.any ideas? Car has 41k on odom.I didn't use the hoses it came with.used the stock hoses.they connected fine.should I use the r2c hoses and reset ecu again?
Old May 15, 2015 | 02:58 PM
TheLocNar's Avatar
TheLocNar
No reason these intakes should be throwing a code. I'd double check your installation, and get the code read. It could be something totally unrelated.
Old May 15, 2015 | 04:47 PM
beachbum718
I changed hoses and tightened clamps more.also gave each sensor a little more turns tight. Reset computer so far no codes.that was a week ago
xxg00w0
Intake and Exhaust
42
Mar 18, 2021 07:44 PM
stm37s
The M - Spot
Oct 1, 2015 06:53 AM
hamkha1ebay
Sep 28, 2015 02:38 PM
SON415
Sep 28, 2015 05:49 AM
