should i get HFC?
Old Dec 16, 2013 | 07:08 PM
yrag's Avatar
yrag
should i get HFC?
i live in NYC and i heard a lot about people getting pulled over and getting tickets for having their exhaust too loud
i have the MXP catback for about a year and haven't got pulled over for my exhaust yet. does anyone have a video comparison MXP cat without and with HFC
if this helps i also have injen short ram intake
i want it louder but i would like to hear a example of how loud it would be with HFC
Old Dec 16, 2013 | 07:41 PM
jesse550's Avatar
jesse550
Buy these: Resonated test pipes lol. They make it louder but the resonators help keep the noise level at non ridiculous levels
Old Dec 16, 2013 | 10:26 PM
yrag's Avatar
yrag
kinda new to this whats the difference between hfc and resonator test pipe or y pip? any gains?
Old Dec 16, 2013 | 10:50 PM
GoFightNguyen's Avatar
GoFightNguyen
Because Racecar
High Flow cats are catalytic converters that have a reduced number of cells per square inch. The lower density allows exhaust to flow more freely while still providing some filtering and cleaning.
Test pipes have no matrix or cleaning. They are just pipes with a bung in the side for an O2 sensor. The will be louder because they do not obstruct the exhaust at all, they will have slightly better horsepower gains. The downside is you may throw error codes, you may fail inspection, and your exhaust will smell from the unburned contaminants.
A Y pipe is just a pipe shaped like a Y that gathers exhaust from your dual catalytic converters/testpipes/whatever and pipes it into a single exhaust pipe downstream.
Old Dec 17, 2013 | 12:21 AM
yrag's Avatar
yrag
thanks very detailed answer. error codes meaning my check engine light is going to turn on right?
so the HFC wouldn't have that issue?
Old Dec 17, 2013 | 12:45 AM
monytx's Avatar
monytx
Yes, check engine light. Reason why I haven't just thrown on a straight pipe. Here in Texas we have emission testing. I don't want to put on the factory exhaust every time inspection comes around.
Old Dec 17, 2013 | 07:41 AM
GoFightNguyen
Because Racecar
thanks very detailed answer. error codes meaning my check engine light is going to turn on right? so the HFC wouldn't have that issue?
Yes. Your check engine light may turn on. It's not guaranteed, depending on the design of your test pipes, you may have zero problems with having them on. If your test pipes have an L-shaped side outlet to screw in your O2 sensor instead of sticking it directly in to the exhaust stream, you'll be less likely to have problems. You can also reduce the chances of getting an error if you stuff a little bit of fine steel wool into the bung before screwing in the sensor. The steel wool will prevent the worst of the exhaust contaminants from damaging your sensor.
HFC's won't have any of those issues anyways, and in my opinion, catalytic converter design is sufficiently advanced that test pipes don't have much of an advantage anymore.
Old Dec 17, 2013 | 07:45 AM
yrag's Avatar
yrag
I wish someone had a video so I can compare
Old Dec 17, 2013 | 07:52 AM
GoFightNguyen
Because Racecar
The differences in sound? Or the physical differences?
Old Dec 17, 2013 | 09:25 AM
InitialC's Avatar
InitialC
I have a couple very short videos, they weren't really done well but I'll put links up to them shortly. They are just short engine rev videos. I have the MXP exhaust and I added the MXP Resonated Test Pipes. Its loud as ****....but I love it! A lot of people mentioned how raspy it can be and it was pretty raspy at certain throttle inputs and RPM ranges. However, when I let someone else drive it and stood outside, I didn't hear the rasp at all. I also realized how well insulated the cabin was from outside sound because the exhaust was much louder than I thought from listening on the inside. I've only gotten pulled over by cops so they could get a closer look at the car and listen to exhaust - no bull****.
Old Dec 17, 2013 | 09:48 AM
InitialC's Avatar
InitialC
Took this the day I got the MXP exhaust put on
Took this before I had the MXP RTPs added
Took this after the MXP RTPs were added
Old Dec 17, 2013 | 09:55 AM
InitialC's Avatar
InitialC
Sorry...the last video (which is the most important) is the crappiest - but you can hear the deeper tone of the exhaust with the RTPs.
Old Dec 17, 2013 | 12:21 PM
budiu22's Avatar
budiu22
Fast Intentions Resonated High Flow Cats!
DOO ITTTTTT!!!!!!!!!!
Old Dec 17, 2013 | 04:32 PM
yrag's Avatar
yrag
Thats crazy lol but new york cops are more of douches. Thanks for the videos now i just need a comparison with the HFC's. Did your CEL turn on?
Old Dec 17, 2013 | 05:39 PM
warped ideas's Avatar
warped ideas
A quarter past stripped
I'll be installing my HFC's this weekend or the next (as soon as they arrive). I'm planning on posting a thread and review on the setup. Be watching for it since I won't pull punches, if its crappy (I doubt it) I'll be sure to let everyone know. Both the pluses and the negatives will be spoken about.
