R2C + Stillen CBE
R2C + Stillen CBE
Just ordered my R2C intake for my 2013 G37S Sedan. Just wondering, will increased engine airflow alter the sound of my Stillen CBE? Would you recommend resetting my ECU after installation? Also, is a tune recommended? If so which is a good tune that can be changed back to stock if needed?
Thank you, sorry for all the questions lol
I'll answer these in reverse order.
Any tune can be returned back to normal. It's just a reprogram of your ECU.
If you plan on changing out your stock cats in the new future, I would hold off on getting a professional tune until you actually get all the bits put in. You'll just have to tune again.
Resetting the ECU via the pedal dance is kind of questionable as to how much that helps, it certainly doesn't hurt; knock yourself out and do it.
Yes the increased airflow will make some sort of note change, I don't know exactly how it will react, but the increased airflow will probably make it slightly deeper at midrange revs. Changing your cats out will do more to change your sound.
Yeah, HFC's make a pretty big difference, but they are definitely a pain in the ***. I have a DIY posted on how to do it. No bueno.
If you don't plan on doing any more mods, yeah, I guess you could tune it. You could probably squeeze a few more HP out of it with a tune.
RexHavoc
Oct 2, 2015 11:47 AM
SON415
Sep 28, 2015 05:49 AM
