motordyne flex pipe leak
Old Dec 3, 2012 | 07:50 PM
GET_SOME's Avatar
GET_SOME
well i knew it was to good to be true. I finally got my ART pipes on my motordyne exhaust and it sounds amazing except for a leak while under load, and its coming from my flex pipes. i know its from scraping them everywhere but it still sucks. my question is it ok to replace them with just strait tubing welded in place or do I have to buy new flex pipes? thanks for your guys help.
Old Dec 4, 2012 | 01:27 AM
huwee06's Avatar
huwee06
Flex-pipe allows the exhaust system to bend when the engine torque. It's not a must, but if you place the flex-pipe with a solid pipe make sure that you also have solid engine mounts. If not your muffler system can crack or bend up, overtime, due to the engine flexing.
Old Dec 4, 2012 | 09:18 AM
GET_SOME's Avatar
GET_SOME
are there any exhaust systems that dont have flex sections? im just worried ill be having to replace the flex sections every 6 months
Old Dec 4, 2012 | 10:47 AM
huwee06's Avatar
huwee06
No, not for our G37's at the very least, unless it's a custom setup. There's a reason why exhausts utilizes flex-pipes as I had simply explained previously so if you're going to delete it do it at your own risk that is all.
If you're so worried about it being crushed again I suggest you change your driving habits
Old Dec 4, 2012 | 11:20 AM
Diego@Vossen's Avatar
Diego@Vossen
My system does not use flex pipes. I never had issues with mine with the previous 3 systems and the past few years running FI.
vamarris
Dec 9, 2018 11:10 AM
conkus805
ECU Tuning / Dyno Data
46
Nov 19, 2015 07:49 PM
Mattimus
Oct 4, 2015 01:33 PM
Msherburneg37xs
Intake and Exhaust
Sep 30, 2015 06:39 PM
rks
Sep 27, 2015 07:38 PM
