Help! new r3c install....
Old Jul 19, 2012 | 09:31 PM
ciddx's Avatar
ciddx
Installed a r2c intake today. Attaching the tube from the crank case to the intake tube was a HUGE PITA. Used the original on the drivers side and the new included tube on the passengers, however I could not get the tube not to kink!
Is this going to be an issue? Drove the car and everything seems fine...but losing a lot of power in 6th....
I want to make sure i'm not doing terrible things to the car....
Old Jul 19, 2012 | 11:07 PM
ashmostro's Avatar
ashmostro
If it's kinking, why can't you just cut the tube down a bit?
I admit I don't run an R2C setup, so I might be missing something.
Old Jul 20, 2012 | 07:48 AM
ciddx's Avatar
ciddx
problem is that the tube is too flimsy and no matter how i install it, its going to kink.
I drove to work without any issues however.
Old Jul 20, 2012 | 07:55 AM
ashmostro's Avatar
ashmostro
I see. Look for silicone replacements online. Just get the right ID and cut to length!
Old Jul 20, 2012 | 01:22 PM
ciddx's Avatar
ciddx
i think thats the route i'm going to take...
had another question, there were plastic boxes attached to the crankcase stem, guessing these were filters? Do i not need filters anymore since i'm running r2c's? is this going to dirty up the engine alot?
Old Jul 20, 2012 | 01:28 PM
ashmostro's Avatar
ashmostro
Those are catch boxes... Re use them and just replace the tube that connects them to the intake.
Old Jul 20, 2012 | 04:36 PM
nickw's Avatar
nickw
I dont have them but dont you think they should fit right out of the box? If you go on replacing the tubing what the hell was the point of buying it lol .
I just ask because I havent seen this issue previously mentioned and I might want some in the future . Maybe someone can chim in with some input.
Old Jul 20, 2012 | 04:50 PM
ashmostro's Avatar
ashmostro
Not entirely sure what your specific question is? Please elaborate, sorry.
Old Jul 20, 2012 | 06:43 PM
g37sFromAdig's Avatar
g37sFromAdig
OK i had the same issue when I installed my R2C. This is what you have to do(I'm a technician by the way). On the passanger side, use the stock hose but flip it around and it will fit perfect. On the driver's, use the stock hose. It will be a little short, so pull it up a little so it will reach the intake tube. If you have any other questions you can PM me.
Old Jul 20, 2012 | 07:28 PM
ciddx's Avatar
ciddx
thanks Adig, i'll give the flip thing a try tomorrow. I ended up buying some tubing just incase.
The drivers side fit fine with a little a little work.
Old Jul 21, 2012 | 01:19 AM
g37sFromAdig
no problem, let me know how that turns out for ya.....
Old Jul 21, 2012 | 02:12 AM
lake985's Avatar
lake985
I just installed mine last weekend, although it was on a sedan (shouldn't really matter). I got rid of the two catch boxes as per the instructions, but reused the two stock breather hoses like previously mentioned. Just flip the passenger side hose around and it fits fairly well. That flimsy piece of hose that came with the kit is ridiculous.
Old Jul 21, 2012 | 04:35 PM
ciddx's Avatar
ciddx
Did the hose flip trick and with a little maneauvering it fit and stayed fiitted. Drove to work today (40 miles) and everything still solidly in place.
Thanks for all the help!
(and that little piece of tubing they send you is definitely ridiculous -- it has no body to it and kinks with every turn)
G37Some
Picture Share G Coupe
24
Jul 2, 2014 01:50 PM
Wezbian
Video Share
14
Jun 16, 2010 11:16 AM
SimonVice
Exhausts
23
Jan 23, 2010 04:47 PM
