Stillen Gen 3 VS Takeda front Mount CAI
Old Aug 28, 2015 | 10:37 AM
  #136
ANMVQ's Avatar
ANMVQ
Imdatguy, No problem man, Just trying to help , Since I have experience with both. I do feel however the dual filters matter, but we'll see. save the $$ and get the takedas. They are legit the same design. Just where the Takedas go through the rad support its a rubber boot. At some point I'd think they would need to be replaced but even at that it wouldn't be a hard change over.
Old Aug 29, 2015 | 12:10 AM
  #137
Jonesmeister11's Avatar
Jonesmeister11
I'm ordering my takeda today actually!
Old Aug 29, 2015 | 01:44 PM
  #138
ThebigJ's Avatar
ThebigJ
Any of you noticed an mpg increase with takeda or stillen's (when you drive the same way you do without them of course). Since Cai's seem to bring this much to this engine maybe with a light foot it may also bring an additional 2mpg's
Old Oct 14, 2016 | 04:12 PM
  #139
Banshee's Avatar
Banshee
Originally Posted by 1cleanG
LOL...gtfo.
The stillen intake has 10x better quality then the Takeda. The Takeda's piping is cheap, the piping has larger and smaller diameters throughout the piping to fit the engine bay and "make it easier to install". Think about it, THIS IS THE SAME concept as an exhaust. Your exhaust can only flow as easy and quickly as the smallest diameter of the entire exhaust. Hense why it makes no sense to have half of an exhaust 3" piping, and the rest 2.5" piping.
Same concept applies here, the Takeda narrows down in diameter to fit through to "avoid cutting", so you might as well just have a smaller pipe through the entire intake. Also, all of the couplers are CHEAP that come with it. I've seen then first hand, and they don't line up.
Last but not least, the Takeda comes w/ one filter, with two pipes pulling out of the same one? What's to say that one isn't over compensating for the other, not to mention the Gen3 comes with 2 quality K&N filters. Doesn't get any better then that.
CHEERS
I just want to say, that from a physics stand point...with a smaller diameter pipe, the air flows with a higher velocity which is a GOOD thing with regards to an intake. Try blowing air through a 2.5 inch pipe as fast as you can through a straw for soda pop and you'll get my idea. The fact that it even changes in size could be beneficial. Industrial and even residential air ducts change in size to accommodate for lost velocity. Just sayin..the physics are there if you wanted to argue.
Also, exhaust is different than intake. For NA vehicles you want back pressure for torque and responsiveness..so different sized piping does not matter as long as the end result is the same. For FI you want straight pipe or as high flow as possible otherwise you'll cook the turbo very quickly. Turbos HATE back pressure.
Old Oct 24, 2016 | 09:59 AM
  #140
Streetking310's Avatar
Streetking310
Stillen that Takeda **** is cheap
Old Aug 31, 2018 | 04:53 PM
  #141
PearlyG's Avatar
PearlyG
LOL...gtfo. Its because of power. I have Gen3's, and the people that complain about the install simply don't know what they're doing and shouldn't be around cars, let alone modding them.
CHEERS
i think you just sold everyone on here to go with Stillen
Old Aug 31, 2018 | 05:05 PM
  #142
Baadnewsburr's Avatar
Baadnewsburr
I don't know about "just"...that post was over 6 years ago...
kavcheung
Intake and Exhaust
Aug 25, 2015 01:07 AM
RobertoG37s
Aug 16, 2015 06:26 PM
SpeedBallDEVIL
Aug 12, 2015 04:30 PM
connoisseurr
Aug 11, 2015 09:30 PM
