y-pipe
Old 08-23-2011, 10:14 PM
Abdiel
Abdiel's Avatar
generally, pipe diameter is inversely related to tone. for example, 3" will have a lower tone vs 2.5" at the same rpm. pipe wall thickness is a factor as well. thicker pipe walls have less tendency to vibrate/buzz.
at least this is how i understand it.
Old 08-23-2011, 10:37 PM
TVPostSound
TVPostSound's Avatar
Originally Posted by WPPJR30
Y-pipe alone will not give you a drastic difference in sound. If you are simply looking for more volume, the HFC's are your best bet.
It will give you a slightly deeper sound! I noticed it with my stock exhaust.
Old 08-23-2011, 10:38 PM
TVPostSound
Originally Posted by 6mtg37s
m2 performance y pipe for $100!
Read post #8 ^
Old 08-23-2011, 10:49 PM
08_g37s
08_g37s's Avatar
Is the m2 y pipe a decent pipe and were can I order it for 100 ?
Old 08-24-2011, 12:49 PM
bukg37
bukg37's Avatar
180 on ebay
Old 08-24-2011, 01:07 PM
hechen507
hechen507's Avatar
I got megan racing y-pipe, match with a berk hfc the sounds is so much deeper then stock.
Old 08-24-2011, 10:16 PM
OB G
OB G's Avatar
Sorry don't mean to thread jack....but does anyone know if the y and mid pipes for the journey/S are the same as the X? Meaning if I get a Tanabe Y and Mid Pipe, will it fix an X?
Old 08-24-2011, 10:51 PM
BooSa37
BooSa37's Avatar
Should be the same...
Old 08-25-2011, 01:50 PM
Ibanez540r
Ibanez540r's Avatar
I have the exhaust depot y pipe on stock exhaust. Didn't really notice a sound difference if at all. Y pipes may affect sound a tiny bit, but will not really be noticeable as far as "sound changing".
Old 08-30-2011, 11:33 PM
bukg37
bukg37's Avatar
Originally Posted by SRG
I have the fujitsubo legalis with berks. The sound is flawless. Especially once you give it a little extra on the pedal. I'm getting an exhaust depot y pipe. How do you like the exhaust so far?
how you like that setup so far, fujitsubo with ed ypipe and berk. i got the same setup but w/o ed ypipe
VQCrew
Intake and Exhaust
18
11-23-2015 08:30 PM
js3350z
Intake and Exhaust
13
02-16-2009 01:11 AM
milelin
Intake and Exhaust
19
08-08-2008 09:28 PM
Quick Reply: y-pipe
