need a new O2 sensor :(
While getting a pair of berk hfc's installed on my car today the left side O2 sensor was damaged. Anyone know where I can get one for cheap? I need one ASAP so time is definitely an issue. Also, (hope I don't get flamed) will my car be able to run for a while with a damaged sensor? thanks everyone.
you will want to get an oem replacement for your O2 sensor. Especially since you are only replacing one side's sensor. A cheap aftermarket sensor might read differently, and i just wouldn't risk having to purchase another one for the good side to compensate. You can run with a bad sensor but your car will have the check engine light pop up till you replace it.
Here you go: Amazon.com: Denso 234-4380 Oxygen Sensor (Air and Fuel Ratio Sensor): Automotive
You can get one day shipping from amazon if it's urgent. This is basically an OEM replacement.
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
