Exhaust diameter question re: Berk HFC to OEM mid pipe
Old Aug 13, 2010 | 12:03 PM
Abdiel's Avatar
Abdiel
Anyone know what the OEM exhaust diameters are?
Header - Out ?
Cat - In 2.25 (ID), Out 2.0 (ID)
Front (Y) pipe - In 1.75 (ID), Out 2.375 (ID)
Mid pipe - In 2.5?, Out 2.5?
Muffler - In 2.5?
I currently have Berk HFCs which are listed at 60mm in/out (2.36in) So this means there is a 2.36->1.75 transition from HFC to Y pipe which is bad (from what I've read).
Is there an aftermarket Y pipe that would solve this without causing the same issue at the mid pipe? For example, I believe the MD XYZ pipe is 2.5 in & 3 out. This would cause 3->2.5 transition from mid pipe to muffler.
Last edited by Abdiel; Aug 14, 2010 at 06:31 PM. Reason: Updated OEM Cat measurements
Old Aug 13, 2010 | 12:28 PM
hispeed-lowdrag's Avatar
hispeed-lowdrag
I can tell you the Berk HFC to OEM piping is no problem whatsoever. I don't know the measurements but I and plenty of others have had that and no issues
Old Aug 13, 2010 | 02:27 PM
Abdiel's Avatar
Abdiel
Yeah, I don't have any performance issues either that I'm aware of, but I don't have a reference (i.e. stock) to exhaustively (ha) compare against to know that there may be an issue.
That said, while 2.36->1.75 may be OK, 2.36->2.36/2.5 is empirically better right?
Old Aug 14, 2010 | 06:17 PM
Abdiel's Avatar
Abdiel
Measured my OEM cats: inner diameter appears to be 2.25 inlet and 2.0 outlet.
Old Sep 5, 2010 | 11:09 PM
Abdiel's Avatar
Abdiel
MY350Z.COM Forums - View Single Post - Motordyne investigation of Y pipe diameter
chuckie311
78
Apr 18, 2016 08:56 PM
VQCrew
Intake and Exhaust
18
Nov 23, 2015 08:30 PM
KAHBOOM
Aug 25, 2015 11:05 AM
RoyalG37
Aug 11, 2015 12:21 PM
bqbal
Intake and Exhaust
Aug 9, 2015 06:43 PM
