HFC Question
Old Nov 20, 2008 | 10:49 AM
Seer's Avatar
Seer
HFC Question
Couldn't we just use Magnaflow or Random Tech cats that have been proven to work on Corvettes, Vipers, Ferraris etc etc, instead of the Berk HFC?
Considering theyre about 60% less in cost too?
Old Nov 20, 2008 | 11:18 AM
rossab's Avatar
rossab
Most people don't want to splice new cats into the stock pipes because they like to have a set of stockers in case they ever need to go back to stock. Some people like to do the install themselves too, which is a lot easier when you just bolt it on.
Old Nov 20, 2008 | 11:21 AM
GNLuver's Avatar
GNLuver
The actual cat parts on all of the aftermarket vendors are Magnaflow cats. You are paying for the R&D and materials on the piping.
Any one have an idea on how much just the cat box costs, just for comparisons?
Old Nov 20, 2008 | 01:45 PM
Gamedog's Avatar
Gamedog
Sam Rothstein
Magnaflow HFC's should work... They were around $90 each last time I checked... But yeah, they should work fine... If anything, you could have a reputable muffler shop just fab you the piping you need to make them work... Shouldn't be too tough IMO...
Old Nov 20, 2008 | 01:50 PM
Seer's Avatar
Seer
I fail to see where there is any R&D work done at all, when I can pay a reputable exhaust guy $50 to make 4 cuts and 4 welds, and be done with it.
It doesn't take genius to cut/weld/bend pipe. But as stated below, the cats are $90/ea retail. So add another $50-$100 to have a shop cut/weld them in.
Old Nov 20, 2008 | 01:51 PM
Seer's Avatar
Seer
I definitely see your point, but from a cost savings perspective it's still cheaper to have them cut/welded in.
Old Nov 20, 2008 | 01:58 PM
GNLuver's Avatar
GNLuver
Also, the new Berks (v2) have a larger diameter pipe. I see you point about four cuts and four welds, though. They are pretty pricey for the little amount of work in them. The local exhaust guru around here put a single 3" ATR exhaust on my Buick TR and put in a high flow magnaflow 3" cat and installed my downpipe while he was at it for only about 400 bucks. I brought in the exhaust and downpipe, but that price included the cat.
Old Nov 20, 2008 | 05:05 PM
w0ady's Avatar
w0ady
if you use the same internals then piping is piping. most of the time you're paying for name so yes magnaflow would work.
Raleclair
Oct 8, 2015 02:06 PM
beng37s
Intake and Exhaust
Sep 19, 2015 01:32 PM
hydronos
Sep 11, 2015 04:04 PM
carid
Supporting Vendors
Sep 10, 2015 10:17 AM
joshferbs
Sep 9, 2015 08:53 PM
