Maganaflow Interior vibration
Old Nov 20, 2008 | 10:21 AM
alofoque's Avatar
alofoque
I installed a magnaflow and ever since the install i have noticed a vibration at low rpms inside the car. Anyone else experience this with the exhaust? I really like it I would hate to have to remove it.
Old Nov 20, 2008 | 11:20 AM
rossab's Avatar
rossab
Is the vibration coming from the exhaust or something inside the cabin...
Jack up your car and check that all the bolts are tight and make sure it isn't rubbing against anything and you have sufficient clearence. You should be able to solve a vibration problem as long as it isn't coming from within the exhaust.
Old Nov 20, 2008 | 12:07 PM
TerribleONE453's Avatar
TerribleONE453
my exhaust rattles pretty much inside my cabin... fail
Old Nov 20, 2008 | 12:15 PM
Gamedog's Avatar
Gamedog
Sam Rothstein
Mine rattles too... Like crazy... But kinda comes hand in hand when getting an aftermarket exhaust fellas... Louder exhaust = Vibration (Eyeglass holder/anything in door slots [water bottles,pens, etc])
Old Nov 20, 2008 | 04:52 PM
NJlakeshoreG's Avatar
NJlakeshoreG
rattles blow..im bout 2 brace my pipes thoroughly!!! lol
Old Nov 21, 2008 | 08:24 AM
alofoque's Avatar
alofoque
It's not really a rattle its more of like a vibration on the steering wheel and shifter. It just urks me!
Old Nov 21, 2008 | 10:01 AM
DetroitG37Joe's Avatar
DetroitG37Joe
My Tanabe makes a little vibration noise somewhere inside the car but only at WOT. I was hoping it wouldnt do that since Tanabe is the most subtle exhaust on the market for the G.
Can anyone locate the exact place where vibration occurs due to the exhaust? I'm sure it would be the same place vulnerable, there would just be a lower threshold for it on more aggressive exhausts. If we can find the place where it vibrates we can see if there's a way to make it more vibration resistant.
Old Nov 21, 2008 | 11:16 AM
aliiin's Avatar
aliiin
BMW Defector
i don't have any or don't notice anything on my borla
Old Nov 21, 2008 | 01:01 PM
The1andOnly's Avatar
The1andOnly
Check if the pipes and brackets are clearing EVERYTHING. BTW, do you have a 5AT or 6MT. I have a 5AT and the HKS, and what's happening is that a bracket in the rear section of the exhaust that's making contact with the differential's heat shield and makes a vibration sound at 2k rpm, but only when deccelerating. This problem only happens with 5ATs though.
Old Nov 24, 2008 | 02:26 PM
alofoque's Avatar
alofoque
It's a 6mt and its just a vibration at like 2K RPM, no noise at all. Ill check pipes and brackets like you said.
fuzzed
Aug 21, 2020 09:35 AM
Upscale Speed
Dec 26, 2015 08:45 AM
Upscale Speed
Dec 24, 2015 12:00 PM
SpeedBallDEVIL
Oct 2, 2015 11:20 PM
Irishcurtis
Sep 30, 2015 11:39 AM
