Full Stock Baseline Dynos compared To nothing
Old Jul 9, 2008 | 10:14 AM
  #106
terrycs's Avatar
terrycs
If there were, the results won't change that much.
Now, off to work for me. Then I'll have to read through several pages of posts after this one.
Originally Posted by NJKSC27
maybe there is actually no dyno
Old Jul 9, 2008 | 10:19 AM
  #107
maxipad96's Avatar
maxipad96
Do not try and run the dyno. That's impossible. Instead... only try to realize the truth.
There is no dyno.
Then you'll see, that it is not the dyno that runs, it is only yourself.
Old Jul 9, 2008 | 10:24 AM
  #108
weave's Avatar
weave
Originally Posted by terrycs
He only posted up his baseline. His post said he was gonna do the after install pulls on Thursday, right? He said that gave him the chance to go back to premium gas and get closer ambient temps. Give the guy till tomorrow night.
He did a baseline, some more pulls after install but he wants to do again tomorrow night when the conditions better match the baseline conditions. Never mind that a Mustang Dyno can correct for these variables....he still should post up what the pulls were. We know the conditions were different but what is the harm in showing us?
Old Jul 9, 2008 | 10:30 AM
  #109
Kream's Avatar
Kream
Big question! Is it still safe to use the intake without removing those covers? I understand that you get more air flow by doing so, but what about keeping stock like how Injen had it setup.
Old Jul 9, 2008 | 10:34 AM
  #110
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
You are not suppose to remove the covers... Thats for track use only... So yes it is safe...
This guy better not dyno it like that either(covers removed)... well until he posts a normal dyno...
Old Jul 9, 2008 | 10:40 AM
  #111
weave's Avatar
weave
Of course he is going to dyno like that, why else would he have taken them off? You have to remove the bumper to put them back in.
I did not come right out and say it in my earlier post but eluded to it... If he has these out when he dynos, then his dyno results are not truly representative of what those who leave them in may see. If Injen wanted them out, they should have included that in the directions or provided new inserts.
Old Jul 9, 2008 | 10:44 AM
  #112
MaxToTheG37
Yes this will not represent the true HP these will make if he has the covers out... No one will drive like this normally, if rains and water then engine kablewy... a few "may" take them out to track the car... but no way daily... even with the covers water still gets in...
Old Jul 9, 2008 | 10:46 AM
  #113
SilverBullet's Avatar
SilverBullet
It appears that there were no major results, if anything a very little increase in hp. Even if he goes back tomorrow and gets a dyno that shows some increase, I do not see how it even matters. Most of us will not be driving at the same temp all the time. So will the intake only be effective on certain days or months when the temp is cool enough and other months be no better than stock?
Old Jul 9, 2008 | 10:48 AM
  #114
MaxToTheG37
Injens dynos were done in 114 degree heat.... just an FYI...
Old Jul 9, 2008 | 10:51 AM
  #115
SilverBullet
Oh ok. Thanks for the information. Then it truly seems like they are going to be a rip. Shouldn't cooler temps be much better for the engine, therefore increasing the hp.
Old Jul 9, 2008 | 11:01 AM
  #116
NJKSC27's Avatar
NJKSC27
of course...a cold air intake should perform better with cooler direct air
Old Jul 9, 2008 | 11:02 AM
  #117
KAHBOOM's Avatar
KAHBOOM
Super Moderator of Pwnage
Yep you should yield more hp and subsequently more gains in cooler temps.
Man the whole issue of how much hp injen really makes has been a grand mystery and yet continues to be. To me this means that I should not get my hopes up.
Old Jul 9, 2008 | 11:08 AM
  #118
NJKSC27's Avatar
NJKSC27
yea i guess we have to face the fact that its just gonna look nice and sound nice
Old Jul 9, 2008 | 11:19 AM
  #119
Buddy Revell's Avatar
Buddy Revell
Not too surprising, considering what COBB and AEM have both said about the G37 and aftermarket intakes:
Originally Posted by AEMG37
I think it is necessary to point out that the brand “N” system is specifically made for the 350Z and most defiantly NOT the G 37. We have concluded as Cobb has, that there is no better way to go than the stock intake system we have dyno tested a fleet of these cars with an amazing array of intakes (and those tested in the Cobb test) as well as others and in every instance, there was a power degradation. (Strangely this is not the case with the 350Z) We even changed the MAF output to see if there was any way to coax more power form the car and that was met with failure. Because we have some electronic skills here with respect to slewing the MAF output signal, we even tried larger diameter intakes with obvious more flow to no avail.
As far as intake flow goes we were able to gain 18% more flow but that did nothing for power which suggests that there may be an issue downstream of the intake system. For example, the Nissan ECU's control the valve timing for best torque while creating a small amount of exhaust backflow into the engine (via exhaust cam timing) for NOx control, no intake system can overcome that situation. Aside from the variable cam timing, the drive by wire (DBW) regulates the throttle opening and on our testing we see that the throttle opening changes as air flow was increased which effectively cost power.
We were able to get a gain of 3-4 hp at the wheels but the system we made to do this would not even get close to fitting in the engine compartment. I will say that what we did do incorporated the stock air boxes. We will not be marketing a system until there are tangible gins.
JC
http://blogs.cobbtuning.com/?p=160
Old Jul 9, 2008 | 11:21 AM
  #120
MaxToTheG37
