Stillen components produce less horse power
Old Jul 1, 2008 | 06:04 PM
db3838's Avatar
db3838
Dyno sheets
here's the charts
Attached Thumbnails Stillen components produce less horse power-beforestillen.jpg   Stillen components produce less horse power-afterstillen.jpg
Old Jul 1, 2008 | 06:05 PM
TerribleONE453's Avatar
TerribleONE453
hmmm yea i would just stick with the parts you have... swap the intake back to stock or for something else.. but with headers and HFCS you cant be loosing HP
Old Jul 1, 2008 | 06:06 PM
DiamondGCoupe's Avatar
DiamondGCoupe
It looks like it went up to 8500 rpms?
Old Jul 1, 2008 | 06:07 PM
Kidcane's Avatar
Kidcane
Florida G Club
Its the ECU, gotta reset it and run for about 1,000 miles before you really knwo what to expect. Then if you still dont see an improvement....you need a reflash.
Old Jul 1, 2008 | 06:09 PM
db3838's Avatar
db3838
And yes... It does feel a little slower... but what I noticed most when I left the dealership was.... nothing. Other than sounding different there was no noticeable improvement in performance.
Is it easy to flash/reset the ECU? something I can do?
Old Jul 1, 2008 | 06:10 PM
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
I think they mixed you dyno up with another car... cause our cars wont go to 8500 unless reflashed and thats still high for a reflash...
Old Jul 1, 2008 | 06:11 PM
MaxToTheG37
Dude... I wouldnt complain... your car is pushin 316whp on a dynojet... that may be the highest NA G37 yet...
I think its in your head... cause you have a FAST G37...
Old Jul 1, 2008 | 06:12 PM
GiGGaplease's Avatar
GiGGaplease
but whos going to continously go to 8500 rpm everytime?
at 5000 rpm, there is only 210 hp. with his mods, he should be higher. what gear did you start in? 6th?
Old Jul 1, 2008 | 06:13 PM
GiGGaplease
go to the drag and post your numbers. you could get low 13's. someone has 13.7 with just an hfc, right?
Old Jul 1, 2008 | 06:15 PM
MaxToTheG37
Trust me... that first dyno is bad... calibration is outta whack... or some technical stuff like that...
Old Jul 1, 2008 | 06:17 PM
NJKSC27's Avatar
NJKSC27
seems as simple as the dynos are mixed up....290ish sounds right with a full stillen setup
Old Jul 1, 2008 | 06:18 PM
db3838's Avatar
db3838
no... it did not make 8500 rpm... he admitted he didn't set up the first rpm graph correctly so when he ran the second set of runs he did not correct it... so that the two runs would be identical.
does that make sense?
Old Jul 1, 2008 | 06:24 PM
DiamondGCoupe
I don't think it's all he messed up on!
That makes sense for sure LOL
Old Jul 1, 2008 | 09:39 PM
  #29
Exhaust Depot's Avatar
Exhaust Depot
Simple test:
What does your butt say? For sure you sould feel a night and day difference on your butt dyno, forget about the dyno charts for now.
I know ive gotten on some cars with mods and it pulls very strong yet the dyno does not show it. Just like a dyno wont show what your intercooler will make because a fan blowing on it does not compare to 80mph air hitting it.
Old Jul 1, 2008 | 10:40 PM
  #30
bboysteele's Avatar
bboysteele
Sorry but like everyone else stated on here there is NO WAY you would loss power over stock. Even if the intake cause you to drop power it would be by 5HP. The HFCs alone would cover that plus give you some power and you still need to count the rest of the exhaust and headers. Sorry but the dyno is wrong.
