Stillen Headers and HFC's Before/After Dynos
Old Apr 1, 2008 | 09:16 AM
  #31
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
Originally Posted by infidsg35
High Flow Cats = 450
Exhaust = 1000+
Headers = 700
Install = 1000
Intakes = 450
Total = 3600!!!
Weight savings prolly 50 LBS, HP gained total prolly 27-30HP Little nicer low end torque 20-25LBS... Now imagion you skip the intakes and get a supercharger! Everything thing will run more efficiant and flow better. You will get better gains from supercharger without adding boost... Plus it will sound MUCH better!
Supercharger is boost....right....
Old Apr 1, 2008 | 09:19 AM
  #32
Kidcane's Avatar
Kidcane
Florida G Club
^^Yes sir!
Old Apr 1, 2008 | 09:20 AM
  #33
infidsg35's Avatar
infidsg35
Ha Ha Ha I wrote that stupidly lol I ment not upgrading from the 8 PSI pully it comes with. LoL
Old Apr 1, 2008 | 09:23 AM
  #34
infidsg35's Avatar
infidsg35
HFCs are closer to 500 bucks... and normally you pay 150 for the install of them.... after taxes and lil stuff your flirting with 2500 bucks... add a cattback installed and your looking around 3700 bucks... add intakes and your looking at over 4k....ouch ouch ouch... but ...hey ... its a hobby... mods are toys and luxury items... you gotta pay to play...
Cat back coasts 200$?!?!?!?
We all make mistakes
Old Apr 1, 2008 | 09:33 AM
  #35
MaxToTheG37
yup we do
its early...what can ya say?
Check your math again...
LOL...
Old Apr 1, 2008 | 10:40 AM
  #36
maxipad96's Avatar
maxipad96
If you get a Supercharger/Turbo, you still need the aftermarket exhaust and HFC's. Plus a handful of other parts + tuning. Buy parts that will one day compliment your forced induction if those are your ultimate plans.
Old Apr 1, 2008 | 11:09 AM
  #37
nestle_!9's Avatar
nestle_!9
man a grand for one horsepower ,,,,,,btw, stillen sells CAI (is this cold air intake) now ? ,, --- from shariffs original post
Old Apr 1, 2008 | 04:55 PM
  #38
SPOHN's Avatar
SPOHN
From Z to G
I agree. But defiantly wouldn't have HFC on a FI system. But also I don't have emissions where I live and I somethimes forget about things like that. Build for the future. But on these motors headers are going to be small, even with FI. The factory manifold flow pretty well on this motor. And obviously turbo's are not going to have turbo manifolds. Unless single turbo. But I don't really see anyone going that route no more on this motor. That's another story in it's self.
Old Apr 1, 2008 | 08:50 PM
  #39
mikelr's Avatar
mikelr
Exhaust = 1000+
Headers = 700
Install = 1000
Intakes = 450
Total = 3600!!!
Weight savings prolly 50 LBS, HP gained total prolly 27-30HP Little nicer low end torque 20-25LBS... Now imagion you skip the intakes and get a supercharger! Everything thing will run more efficiant and flow better. You will get better gains from supercharger with the 8 PSI pully ... Plus it will sound MUCH better!
Your stacking HP numbers a bit there, it doesn't usually work that way. I think that realistically a total gain of 15-18 HP would be all you can expect with a factory tune.
Old Apr 1, 2008 | 09:09 PM
  #40
GiGGaplease's Avatar
GiGGaplease
i disagree, with a hfc and exhaust, you are already around 18 hp. with the other things, you can get it up around that mark.
Old Apr 1, 2008 | 09:43 PM
  #41
infidsg35's Avatar
infidsg35
Me doing RICER math?!?!?!?!?!? LoL There is a dyno showed above that CATS and Headers add 17 HP but you say that realistically 15-18 for headers/exhaust/CATS/Intakes.. So intakes and exhaust = 1HP?
Old Apr 1, 2008 | 10:13 PM
  #42
Dieseldoug22's Avatar
Dieseldoug22
One thing you have to remember is that you cannot add up the supposed gains from each piece and voila... huge power gains. Some pieces work with each other and some take away. So your numbers are going to be less than you would think... or hope.
Old Apr 1, 2008 | 10:56 PM
  #43
maxipad96's Avatar
maxipad96
Why wouldn't you want HFC's w/ a turbo? I have always been under the impression that with a turbo engine the object is to decrease backpressure as much as possible. Unlike a NA engine. Are you speaking from purely an emmissions/smog point of view?
Old Apr 2, 2008 | 08:13 AM
  #44
mikelr's Avatar
mikelr
Of course no cat with a turbo set up would be optimal but I would say that if you needed to stay smog legal that a metal substrate as opposed to ceramic would be wise considering the fact that a FI setup runs very rich for saftey. The unburned (or still burning) fuel that exits the cylinder, thru the turbine and on to the cat can melt down a mortal cat under track duty. I've seen this a few times on aftermarket turbo applications.
Old Apr 2, 2008 | 08:24 AM
  #45
mikelr's Avatar
mikelr
Exactly, and one thing that is not being accounted for are fuel trims. You really have to come back after a few hundred miles and re-dyno for accurate results. 3,4,5 pulls on the dyno doesn't allow time for an accurate representation of true HP gains from a mod. My estimate of 15-18 honest hp was on the conservative (realistic) side, some may see 20hp. I highly doubt 25-30 would be obtainable with intake and exhaust without ecu tuning.
But hey, prove me wrong.
