ECUs
Old Dec 6, 2007 | 01:13 PM
inkum's Avatar
inkum
ECUs
Okay, I'm stupid. What is the ECU and why must it be reset after installing Stillen intakes? Or, the battery disconnected? Dealer (what do they know) says after about 100 miles with new intakes, computer teaches itself??
If the battery is disconnected, is that going to screw up navi, etc.?
Old Dec 6, 2007 | 01:43 PM
An ECU is an electornic control unit. It's a computer that does what the name says, namely control almost every functon of the car including air fuel/ratio, throttle, and many, many more of the car's fucntions. It is set to certain parameters from the factory that are slightly "detuned" from all that the car could achieve if it were programmed a little more agressively. This is to enhance reliability but at a slight cost in performance.
Resetting it causes it to "relearn" everything after you turn the engie on and run it again. Hence, it will relearn things with the modificatins you made (e.g. exhaust, intake, etc.) and not in stock form. This is not the greatest description but I hope it helps.
Disconnecting the battery does not hurt anything, although you'll likely lose radio presets and things like that.
Old Dec 6, 2007 | 02:25 PM
DiamondGCoupe's Avatar
DiamondGCoupe
I posted the ECU reset process in FAQ DIY section.
Old Dec 6, 2007 | 10:53 PM
UNV-IT46's Avatar
UNV-IT46
Sounds like a pretty good description to me
Old Dec 15, 2007 | 12:44 AM
VRG37S's Avatar
VRG37S
How long do you have to leave the battery dissconnected?
Old Dec 15, 2007 | 01:26 AM
I don't know the minimum time, but most leave it overnight and it always resets. So 8 hours will do it for sure, but I've heard as little as 2 hours.
Old Dec 15, 2007 | 02:12 AM
JLai's Avatar
JLai
You don't really need to reset it. Just start driving and the ECU will adapt to the new mods after a while.
navecm
16
May 15, 2021 01:17 AM
wissamk08
Oct 21, 2013 03:54 PM
jbell
Oct 12, 2013 01:17 PM
xorbitman
20
Jun 16, 2013 07:19 PM
dpjones
34
Apr 12, 2010 05:57 PM
