Plenum Spacers for G37?
Old Dec 3, 2007 | 11:29 PM
DiamondGCoupe's Avatar
DiamondGCoupe
Anyone heard of one yet..? Would the G35 plenums work?
Old Dec 5, 2007 | 01:58 AM
notsoricer's Avatar
notsoricer
g35 plenums will not work.. totaly different set up
Old Dec 5, 2007 | 11:46 AM
KAHBOOM's Avatar
KAHBOOM
Super Moderator of Pwnage
The Plenum mods were the best NA mods for the G35 IMO. They produced the easiest and safest gains. Intakes don't work very well on VQs. Exhuasts add some high end but you lose a little on the low end. The plennum mods gprovided gains throughout the powerband.
Old Dec 5, 2007 | 02:00 PM
DiamondGCoupe
Well hopefully someone will come out with one sooner than later.
Old Dec 6, 2007 | 08:09 PM
Jason@Riverside's Avatar
Jason@Riverside
totally different set up then mentioned above...
With the design of the plenums on the VQ35HR and VQ37VHR they are totally different types of manifolds...
One thing I have looked into is mounting the VQ35HR on a VQ37VHR and Vice Versa to change the power band like changing the lower collectors on the VQ35DE Zenki / Kouki motors...
To go between the VQ35HR and VQ37VHR manifolds, the lower collector AND manifold will have to be changed...
Some of the factory gaskets on the VQ37VHR are pretty nice. The intake collector gaskets are 3 layer metal unlike the 1 layer metal on the VQ35HR/DE.
Old Dec 25, 2007 | 11:47 AM
SchoonerVanHlmt's Avatar
SchoonerVanHlmt
Anyone have any info on aftermarket plenums for the G37 yet??
Old Dec 25, 2007 | 02:37 PM
MaxToTheG37's Avatar
MaxToTheG37
Super Moderator w/ Boost
Can someone explain why these give more horspower?
thanks...
Old Dec 25, 2007 | 03:31 PM
wireboltman's Avatar
wireboltman
I figured there'd be an explanation over here. There are other makes, too.
I happen to have one of these on my FX35. All part of what makes me go faster.
http://motordyneengineering.com/techinfo.htm
Old Dec 25, 2007 | 06:25 PM
izzo01's Avatar
izzo01
thanks...
well in the early G/Z cars the manifold had an uneven design were the intake runners at the rear ( I believe ) didnt recieve as much intake air and the forward runners. People like motordyne, skunk2, etc. designed a spacer which rasied and evened the upper half of the intake manifold which gave more power because the airflow was equalized.
that pretty much the gist of it. I dont think the later (HR) motors or the vq37 will see too much of a gain as relative to the first cars cause Nissan has fixed this in house.
Old Dec 25, 2007 | 08:50 PM
MaxToTheG37
That website was a good read... Thanks...
Seems like an easy install too? or is it suprisingly hard...
i like things that dont rack my brain on the install and show good results...
what companies may have interest in our cars?
Old Dec 26, 2007 | 12:33 AM
bboysteele's Avatar
bboysteele
I have also heard this. There has been a lot of talk that a Spacer is not needed or wouldn't even help. I wonder if it is true and I am waiting for a good spacer and have someone run numbers.
Old Dec 26, 2007 | 04:49 PM
izzo01's Avatar
izzo01
I'll help to a point because your increasing the amount of air the manifold can hold ... but if you get too crazy (which is a very thin line ) with increasing the size you wont be tuned for all that extra air.
Old Feb 27, 2008 | 06:28 PM
Lastchance's Avatar
Lastchance
I caled Motordyne 2-22-08 and they said they have nothing in the works as far as plenum spacers go. It sounded like they will not be able to make them for the VQ37. The guy said he is looking at the manifold though but I have no idea if they could actually improve it.
Old Feb 27, 2008 | 06:31 PM
Kidcane's Avatar
Kidcane
Florida G Club
^^YUP^^ https://www.myg37.com/forums/engine-drivetrain-and-forced-induction/178043-intake-manifold-and-now-exhaust.html
Old Feb 27, 2008 | 09:04 PM
vinnys coupe's Avatar
vinnys coupe
dammit i was interested in this mod simple hp gain.. (true hp) not intake sticker BS
