fyi about grounding wires
Just went Best Buy intall area and asked about the 8 gauge wire for the engine grounding to 4 different points of the engine.
It seems like the guys were competent about their wiring schematics and they said I'd be better off doing a one point ground with a 4 gauge wire with the shortest distance. Now, I'm confused. What are your input on this?
Obviously 4 gauge wire is much larger and therefore capable of conducting more current. The shorter the path current travels, the less resistance it will encounter so they were right on that count too. As far as grounding only one point, my opinion is that it depends. One effective grounding point will do more good than 4 points that really aren't grounding anything. 12 wires isn't necessarily better than 3 or 4 if the 3 or 4 are grounding more effectively than 12 redundant or ineffective ones.
Your first mistake is thinking Best Buy knows anything about car installation. Their tech all just pass written tests. They don't require any hands on experience or assess training levels, if you can read a book and pass a test, you can become a Best Buy Installer. Why not go with the tried and true method, whomever came up with this method of grounding has probably experimented with other variations and probably found this method works the best.
Systems on paper can operate completely different than in real life.
Making your own ground wires isn't that hard and if you want, there's a couple vendors on here that will make them for you. I've made two wires for Her G37 so far. A battery to chassis and a chassis to engine. Both were made out of 4 gauge. Because I like to overdo things, I plan on making one more wire and that will be somewhere off the transmission to chassis but I haven't scoped that out yet.
I've never heard of using so many grounds before. That's just silly. All you really need is one good solid ground to the engine. If it helps you sleep better at night then use two. You can say what you want about these installers but in this case they are right.
I think that guy had a Delorean. Cuz the "Back to the Future car" is made of some sort of aluminum and can't be painted. So the best thing to use to get the shine is a fine steel wool.
I have to disagree with you about one thing: on a "V" configured engine like ours, it can be of benefit to ground both sides of the engine to the body. Not always, but in our case this is true. There are also other components that will benefit greatly; throttle bodies, ECU, automatic transmission housing, etc.
As far as the other components, I agree with you on the transmission housing but only because of the fact I like to overdo things. The ecu would have to depend on how bad the thing was engineered. I doubt that it suffers from a poor ground but I could be wrong. The throttle bodies, I don't think I want to talk about grounding the throttle bodies.
RexHavoc
Oct 2, 2015 11:47 AM
dedmanchan
Sep 24, 2015 11:25 PM
