GB Cheap Adjustable Sway Bar End Links $80
Thanks for the kind words.
The fronts are rather difficult. There are no existing rod ends or heim joints that are short enough for our front end links. I've been experimenting with some heim joints, but I had to trim them to the right length. It would be unrealistic for me to organize a group buy where I would need to trim every part. I've contacted a few manufactures to see if they produce shorter joints for us, but since our purchase volume is low, they are either uninterested or the prices are unreasonable. But I'll keep working on it.
Fyi,for those that do not have access to a lift, the space available where the end link fastens to the body is very tight, making it difficult to get enough leverage to loosen the bolts. The higher the car is the better. My driver side end link was a pita to remove even have hitting it with PB Blaster several times and letting it soak.
I know, I know. I've been test running a heim joint front end link setup for the last few months. It's running great so far. However, it did require some modification. So a group buy is impractical. If you guys want, I can post up a DIY and you can do it yourselves. It ended up costing around $200.
