08158-62033 measurements
Old Mar 14, 2026 | 03:08 PM
AdamBritt's Avatar
AdamBritt
Anyone know what the measurements on this general bolt? Snapped one on my valve cover and wouldn't mind knowing what I need to get at Lowe's to get it out and fix the threads before I walk 3 miles.
Thanks
Old Mar 15, 2026 | 11:43 AM
13_SkylineSedan's Avatar
13_SkylineSedan
Searching that number comes up as a "crankcase sensor bolt". Not sure you can get exactly what you need from Lowes as this is likely a specifically made bolt. But Nissan (or even eBay) should have what you need.
Old Mar 15, 2026 | 11:58 AM
AdamBritt's Avatar
AdamBritt
It's M6x1.0-25 if anyone else needs it. I snapped it off in my valve cover replacing the ignition coil pack and was hoping to find what size bit I would need to drill it out. I think for the coil packs a bolt with a washer from Lowe's might suffice. I called the nearby dealer but the parts people decided to leave early yesterday.
spankgo
Feb 8, 2024 04:11 PM
Jhaby
Jan 12, 2021 09:12 PM
ThebigJ
Jan 27, 2017 07:48 PM
Brakery
Mar 13, 2016 09:59 PM
