Help G37 accelerate slow and starts without pressing brake pedal
Old Jun 24, 2025 | 09:59 AM
JTaylor16007's Avatar
JTaylor16007
My 2010 G37x accelerates really slow but eventually gets speed. I made a mistake and put 87 in about 2 weeks ago. I've always ran 93. but I ended up in this small town that just had regular only. I've cleaned the throttle body and performs a little better but not as normal. I did notice when turning corners it jerk so I feel like it gas related. I did top it off twice no change. There's no CEL showing. Also I noticed some weeks ago that it will start without pressing the brake but my brake lights work fine. Anybody experiencing this problem?
Old Jun 24, 2025 | 10:59 AM
ILM-NC G37S's Avatar
ILM-NC G37S
If you can start your engine without ever touching the brake pedal then more than likely there is a problem with the brake pedal switch. While your brake lights might function as normal, these switches handle more than just your brake lights and, as such, there could be a intermittent short, corrosion, or other issue with the switch. This would also explain your lack of power/ jerking/ drivability issues that your are experiencing as your car is receiving mixed signals. It has happened before where TCS cuts power under unusual conditions. I doubt your issue is fuel-related.
Look under the dash and check all of the brake pedal switches- there are two (2): 1 brake and 1 ASCD. Make sure connectors are clean and tight and that the switches are solid in their brackets. There are small rubber pads that contact the switch plunger- these are known for deteriorating and breaking off. Depending on your skill level- and if you have a digital multimeter- probe the switches for continuity. Worst case scenario replace the switch(es).
Noddy11
Nov 17, 2025 02:40 PM
Franklin_lagos
General Tech Questions
Jun 24, 2025 09:53 AM
corkyboy
May 23, 2023 06:46 PM
JEBperformance
Nov 17, 2011 01:33 PM
chasemyaccord
Mar 10, 2008 12:01 PM
