Help Brake lights stay on and weak acceleration
Old Oct 6, 2024 | 12:52 PM
Bradze's Avatar
Bradze
I figured brake switch but even with a new OEM brake switch the brake lights and third brake stay on after ignition is shut off. Car starts without holding brake pedal. Cruise still comes on. Car drives fine except weak acceleration. My ‘10 G37 base automatic coupe is relatively stock power train wise, just 3” exhaust and cold air intake.
Old Oct 6, 2024 | 01:26 PM
ILM-NC G37S's Avatar
ILM-NC G37S
Did you check the rubber pad that contacts the brake switch? These are becoming more prone to breaking as these cars age.
See this thread which will show you what to look for.
I used OEM but Dorman p/n: 74015 seems to work just as well.
With this pad missing the brake lights remain on and the car "thinks" you are braking which is why acceleration is weak. The car is essentially "confused."
Old Oct 7, 2024 | 11:41 AM
Bradze's Avatar
Bradze
thank you so much! I didn’t know this was a thing. So that’s what that broken piece of plastic is on the floor. Thought it was junk because of all the other work I’m doing to the car.
This makes me smile. Been disconnected battery and scratching my head a few weeks. Knew it was something simple.
Bradze
Jul 19, 2025 12:03 AM
topslop1
Jan 3, 2023 10:01 PM
AnotherVQ
Dec 11, 2022 11:35 PM
Devil_g37
Feb 6, 2022 10:44 PM
spoolin03
Dec 20, 2021 08:28 PM
