Help 2013 G37 Sedan AC intermittently blows warm
Old Jul 19, 2024 | 09:48 AM
Marcel4t's Avatar
Marcel4t
I have an issue where when accelerating from a stop AC blows warm for a while. Also takes forever to get cool up on cold start. Blows cold at highway speeds. I hooked up some gauges to see what was going on. 90* with a feels like of 100*. Low side seems high and high side seems low. I also noticed that the low side pressure rises a lot when revving engine up (95psi). I'll attach pics of idle pressures. I tried to upload the pressure when I rev up the motor but it won't upload.
Old Jul 19, 2024 | 10:56 AM
ILM-NC G37S's Avatar
ILM-NC G37S
Are the fans running? 90% of all AC issues with these cars can be attributed to the fans or dirt/ debris clogging the radiator/ condenser fins.
Old Jul 19, 2024 | 11:00 AM
Marcel4t's Avatar
Marcel4t
Thanks, yeah, I thought about the fans, and they are running. But maybe they shut on and off and I dont know?? How would I be able to tell? Do you think my pressures are OK or something wrong with them?
Old Jul 19, 2024 | 11:35 AM
ILM-NC G37S
This post will show you how to run the IPDM/er self-test which tests the fans. BOTH fans, during this test, should run at 50% duty (medium) for 5-seconds, then "ramp up" to 100% duty (full-speed) for a additional 5-seconds. At full speed they should BOTH be roaring loud and moving a ton of air.
With the AC set to 60 (MAX cooling) the fans should be at 100% with the car idling.
I will let others chime in on the pressure gauge readings.
Old Jul 20, 2024 | 06:46 AM
SkysG37's Avatar
SkysG37
The IDPM turns the AC clutch off under acceleration, right?
But not the blower fan(s)
And the heater core is always hot, so maybe look at the blend door
I installed high temp shut off valves to keep my heater core isolated. Helped cab temps tremendously.
olated.so did ditching the cats and wrapping the headers
Old Jul 20, 2024 | 10:17 AM
ILM-NC G37S
Not exactly. The ECU/ IPDM/er only turns the compressor OFF under the following conditions:
Under normal acceleration the comoressor remains engaged.
Every indication, based on OP's symptoms, leads me to suspect insufficient airflow across the radiator/ condenser.
G37WICKED
Aug 26, 2023 11:33 PM
Q1808
Aug 17, 2023 08:55 PM
mdanish4
General Tech Questions
Jun 4, 2019 02:47 PM
Phenomenon9
Sep 15, 2016 01:36 AM
