Rear window 1/2” lower than front window
Old Sep 24, 2023 | 09:52 PM
petemo94's Avatar
petemo94
So on the driver side of my Vert, the rear window is slightly lower than my front window. This causes wind noise at highway speed.
Has anyone have a way to level the window? The passenger side windows are of the same height.
Picture shown
Old Oct 15, 2023 | 09:40 AM
petemo94's Avatar
petemo94
Bump to top to see if anyone has ever fixed a window problem like this one
Old Oct 15, 2023 | 10:41 AM
ILM-NC G37S's Avatar
ILM-NC G37S
The GW (Glass & Window) section of the FSM (attached below) has detailed instructions on checking glass height and how to adjust the regulator to compensate. Being that the passenger-side is "normal" means that you can take those measurements and apply them to the driver-side.
Based on the OP's picture, without those measurements, it is impossible to say which window needs to be adjusted. However, depending on how long the window has been "out of adjustment" and, more importantly, "why," the upper roof seal may already be deformed due to the added tension.
File Type: pdf
Old Jan 11, 2024 | 05:46 AM
Stra2d's Avatar
Stra2d
Try doing a window reset
ezbme
Dec 15, 2021 05:28 PM
Kboyd
May 9, 2018 02:51 PM
DeanMachine
Mar 14, 2017 01:23 AM
CrazyBulgarian
Feb 20, 2013 01:53 AM
