Small Cover Under Car Falling Off
Old Jan 4, 2020 | 06:41 PM
wbarnum's Avatar
wbarnum
Question Small Cover Under Car Falling Off
Hey all,
I realize this is a minor thing, but I noticed this cover under the front end of my car seems to be falling off.
It appears that there is a third screw or bold that is missing. Does anyone have any idea where I could get a replacement for this?
Thanks in advance,
BIll
Old Jan 4, 2020 | 07:20 PM
PNW_IPL's Avatar
PNW_IPL
ACE lowes home depot
Old Jan 4, 2020 | 08:49 PM
Epiphany's Avatar
Epiphany
It's actually hinged across the back and is broken. Mine came apart a couple years ago, but was also broken where one of the bolts goes. I just cut it off and left it as is.
Old Jan 4, 2020 | 08:54 PM
wbarnum's Avatar
wbarnum
Thank you! That is very helpful.
Old Jan 4, 2020 | 09:16 PM
Said Amir's Avatar
Said Amir
Punch a hole and zip tie that sucker
Old Jan 5, 2020 | 02:35 AM
crookncastle's Avatar
crookncastle
amazon carries those bolts.
Amazon Amazon
those bolts will fit a bunch of other stuff on infinitis',nissans', hondas', and toyotas'
Old Jan 5, 2020 | 11:10 AM
wbarnum's Avatar
wbarnum
Good idea. I ended up doing it and it seems solid enough.
Old Jan 6, 2020 | 09:21 AM
Surfnazi's Avatar
Surfnazi
You need the metal bracket that has hole that's threaded. Its 2 bucks for that u shaped clip
Old Jan 6, 2020 | 09:33 AM
NealP's Avatar
NealP
Isn't that the hole for oil change/oil filter? If you don't want to or can't fix it properly you're probably better off just removing it. Securing it with zip ties, especially if you don't do your own oil changes, will be a pain each oil change as it will have to be removed and you'll end up back where you started.
Old Jan 6, 2020 | 06:50 PM
Surfnazi's Avatar
Surfnazi
Or get fancy and order an aluminum access panel from amazon
Old Jan 15, 2020 | 01:04 PM
Conboss's Avatar
Conboss
Lop it off or zip ties.
iCrap
Mar 20, 2018 06:07 PM
sLADe781
Car Care & Detailing
Nov 21, 2014 11:10 AM
newspider4re
Aug 30, 2011 07:52 AM
levin91e
Apr 23, 2009 10:29 PM
