VDC (vehicle Dynamic control) light on randomly
Old Dec 30, 2019 | 01:06 PM
nicaland's Avatar
nicaland
Recently, my 2012 G37S VDC dash light has started to occasionally turn on solid (not blinking) randomly, and in every case not in conjunction with hard driving to any degree. Stopping, turning off the car and re-starting turns it off again, but at some point that really doesn't appear to be mileage dependent it turns back on. The car is lowered, but has been for 40,000 miles, all suspension components are good and tight, and although my brake pads are about half their thickness when new I feel that they will not require replacement for quite some time yet. Any ideas?
Old Dec 30, 2019 | 01:49 PM
Surfnazi's Avatar
Surfnazi
Low brake fluid or worn tires
Old Dec 30, 2019 | 01:57 PM
nicaland's Avatar
nicaland
Thanks for the quick response but nope. Brake fluid level is fine, almost exactly between high and low level indicators, and the tires are new Michelin Pilot Sport 4S's with less than 1000 miles. BTW, these are beyond a doubt the best I have ever owned, dry or wet, quiet too. Just incredible tires.
Old Dec 30, 2019 | 03:35 PM
slartibartfast's Avatar
slartibartfast
Top off the brake fluid reservoir and report back. Seriously, top it off.
Old Dec 30, 2019 | 03:44 PM
Surfnazi's Avatar
Surfnazi
they are good I use those and Bridgestone potenzas s04
Old Dec 30, 2019 | 03:48 PM
nicaland's Avatar
nicaland
slartibartfast......OK, will do. Certainly worth a try!
Old Jan 4, 2020 | 01:19 PM
Surfnazi's Avatar
Surfnazi
Check for brake line leaks especially if your brake pedal is mushy
Old Feb 3, 2020 | 06:08 PM
nicaland's Avatar
nicaland
OK you guys, it looks like (so far) you were right! Topped up brake fluid to full mark, and around 500 miles later, no weird VDC light showings. Cheers!
CleanAsFuhh
Jan 8, 2025 03:12 PM
37hevn
Mar 21, 2020 06:15 PM
FlameOn
Feb 12, 2020 03:03 AM
marcopolo15
Mar 29, 2012 12:43 PM
hurubi
General Tech Questions
Oct 4, 2011 02:46 AM
