Just bought an used 58K miles 2013 G37 sedan. Suggestion on maintenance?
Old Nov 1, 2019 | 01:50 PM
jt2499's Avatar
jt2499
Hey guys,
Been a lurker here for a while. I always wanted one but never committed to it. I finally pulled the trigger last night and the car drives perfect. However, the car was a fleet vehicle and I know that some fleet companies don't care of their car. At 58K miles, what would you recommend for me to replace and maintenance?
As of right now, I'm looking at
Oil Change
Oil filter
Transmission fluid
Resurfacing brake rotors (it's a maybe, the brakes have no problem at all)
Much appreciated!
Old Nov 1, 2019 | 02:13 PM
PNW_IPL's Avatar
PNW_IPL
All of it.
Plugs
Oil
Air filters
Coolant
Trans 3x3
Diff
T case if awd
Lube chassis
Power steering flush
New belt
Alignment
Old Nov 1, 2019 | 02:34 PM
Originally Posted by PNW_IPL
All of it.
Plugs
Brake Fluid
Oil
Air filters
Coolant
Trans 3x3
Diff
T case if awd
Lube chassis
New belt
Alignment
He's right. If you don't have an automotive history, then start ownership with a baseline of every fluid swap and tune-up. That way you'll be able to plan what to do or not to do in another 15k and 30k miles, etc.
60,000 is a nice round starting point to look back on. That gives you 2000 miles to figure it all out.
Peace of mind is priceless.
Old Nov 1, 2019 | 04:09 PM
jt2499's Avatar
jt2499
All of it.
Plugs
Oil
Air filters
Coolant
Trans 3x3
Diff
T case if awd
Lube chassis
New belt
Alignment
Sorry to sound like a newbie, but what does diff refer to. And doesn't the g37 have a chain instead of belt?
Thanks!
Old Nov 1, 2019 | 04:10 PM
PNW_IPL's Avatar
PNW_IPL
Thanks!
No worries.
Differential.
Yes timing CHAIN.
I'm referring to serpentine belt.
Old Nov 1, 2019 | 05:50 PM
Selym's Avatar
Selym
Lube chassis
Are there any grease fittings? I didn't think there were.
Old Nov 2, 2019 | 07:10 PM
codeflux's Avatar
codeflux
20 Year Member
https://owners.infinitiusa.com/conte...ance-guide.pdf
Old Nov 2, 2019 | 10:12 PM
Surfnazi's Avatar
Surfnazi
All of it.
Plugs
Oil
Air filters
Coolant
Trans 3x3
Diff
T case if awd
Lube chassis
New belt
Alignment
Do tensioner pulley if you change belt. Also flush brake fluid and ps uses atf
Tones11
General Tech Questions
Feb 21, 2017 05:53 AM
Koval88
14
Feb 19, 2016 11:53 AM
dan10
Aug 23, 2014 08:06 PM
LoveLife
Jul 3, 2012 09:23 AM
blueninjabron
Jun 1, 2011 05:05 PM
