What basic maintenance procedures are you doing?
Hey all, just bought a 2009 G37s and loving it. It was 27,300 miles out the door, and I already put 1,000 on it approximately. What basic engine maintenance should I be performing?
Here is what I already understand: oil change and oil filter replacement every 3,750 miles.
Brake pads when needed.
Rotate tires every 7,000 miles.
What else should I be keeping track of as the miles pile up? How often should I change transmission fluid?
Thank you for all your help, I appreciate it.
Hey man, Tranny is sealed, So like 100k( Think is the same as the 10-11') Oil I do every 2500 but I'm FI, But still did it then NA. Air Filters every 3rd oil change like 8-9k, Just about once a year. Tires, We( Wife) rotates at 5k. Rear diff is at 30k I think?
It depends on your driving patterns. Are you babying it or driving aggressively? Hwy vs local? If you look in your manual, it'll list a couple different service intervals. But since you bought the car used it might not have it.
PDF: http://x.infinitihelp.com/service/20...vice_guide.pdf
What do the maintenance records say?
If the rear differential fluid hasn't been changed, it wouldn't hurt to do it.
Brakes should be flushed every 2 years to maintain peak performance.
Cabin air filter each year / 15k
ATF is "life", although you can probably get a dealer to do it for you.
MT has a DIY and would be a good idea on a used car to change out immediately.
The maintenance manual has all the recommendations and past history for your car. Check it and report back if you'd like to discuss.
I follow what is in the users manual. Already did my brake flush. My rear diff flush. I work on everything expect for major engine problems. I try to avoid the stealership.
Since your's is used I would do everything ASAP and follow your manual from there.
04G35NYC
07-19-2016 01:42 AM
Junchao Sun
25
10-01-2015 12:41 PM
dedmanchan
09-24-2015 11:25 PM
