Help The “Other” Clutch Safety Switch
Old Jul 29, 2019 | 10:15 AM
sobeIPL's Avatar
sobeIPL
I replaced the clutch safety switch right behind the pedal about 6 months ago and my car is having trouble starting again. The contact on the switch is fine (I also tried by using my finger to push it in and same issue). Either that part is bad or it’s the “other” switch. I tried following the linkage but it seems to get lost up in the steering column somewhere.
My question is: is this switch reasonably easy to swap like the other one and where the heck is it? I figured I would just replace both since the parts are cheap but if it’s a tough job maybe I should just replace the easy one to see if that works.
Old Jul 29, 2019 | 01:29 PM
JSolo's Avatar
JSolo
Just say no!!!!!
There's only one switch in the clutch assembly used for starting purposes. The other is to disengage the cruise control when active.
For testing purposes, you can pull the connector in the switch that's actuated when the pedal is to the floor and jump it out. See if you have any issues starting. If not, then the switch should be replaced. If issues continue then it's not the switch.
If you're able to get in there to disconnect both, fit a wrench on the lock nuts then pedal removal should not be necessary.
Capt Donkey
Feb 6, 2023 01:37 PM
32
Sep 14, 2018 12:42 PM
thdrew
May 8, 2018 09:31 PM
mastorian
MODDING 411
Feb 20, 2010 11:34 PM
