Water gets rid of squeak?
Old Mar 19, 2019 | 05:42 PM
g37_black's Avatar
g37_black
Hey guys,
Noticed my car squeaks a bit on cold start up, nothing after it's been running a few minutes. Before I go buy this new belt tensioner, which I think is the problem, I noticed that when I pour water on the belt while it's running, the squeak goes away for a short period of time. Does this tell anyone anything? It is a brand new belt. Just trying to make sure I'm not wasting money because I can't return the tensioner once installed. TIA.
Old Mar 19, 2019 | 06:32 PM
slartibartfast's Avatar
slartibartfast
That usually indicates belt slip.
Old Mar 20, 2019 | 01:00 AM
Said Amir's Avatar
Said Amir
Did you buy a cheap serpentine belt, or a good expensive one? I replaced mine with continental and it works perfectly and it’s similar to oem material that they use on their belt. If it started sqeeking when you installed the serpentine belt then that is the issue. If anything check the tensioner and also the pulleys make sure their is no play in them, and this should be done with the car turn on so you can see the belt rotating and pin point from which pulley it is coming from.
Old Apr 12, 2019 | 03:19 PM
g37_black's Avatar
g37_black
After replacing the belt, and tensioner pulley, I figured out the squeak I had was coming from the alternator (pulley). Alternator was good, but couldn't deal with that squeak. I work for LKQ so I got a used one for like $60.00.
Just FYI.
Old Apr 13, 2019 | 03:24 AM
Said Amir's Avatar
Said Amir
Just FYI.
glad you got it solved!
Old Jul 26, 2019 | 04:51 PM
Surfnazi's Avatar
Surfnazi
So it's a rust stabilizer like other products? I've used similar product then used dr colorchips or touch paint depending on area
Old Jul 27, 2019 | 01:05 PM
slartibartfast
Wrong thread?
Old Jul 27, 2019 | 02:03 PM
Surfnazi's Avatar
Surfnazi
Wrong thread?
Yeah I dont even know how it linked to this post, i think my phone is haunted and trying to kill me
TheLocNar
Jun 1, 2015 11:36 AM
