Jack Stand Locations
Old Sep 5, 2018 | 07:26 PM
BasicallyAG's Avatar
BasicallyAG
If you are using the pinch welds for jack stands, where do you fellas put the floor jack to jack up the vehicle? I have a AWD, anybody use the diff? With a puck on the jack that shouldn't hurt the outside case right?
Old Sep 5, 2018 | 07:58 PM
AdamBritt's Avatar
AdamBritt
I think I did control arms when I put mine up on stands to do the brakes. Might have done the transmission housing for the rear but I have a MT.
Old Sep 5, 2018 | 08:34 PM
saywat?'s Avatar
saywat?
i jus jack up a spot close to the pinch weld.
at the britt: use the rear diff man
Old Sep 6, 2018 | 08:38 AM
Baadnewsburr's Avatar
Baadnewsburr
To get the front up I used to use the jacking point at the very front under the subframe as per the owners manual , but on swifts my ar is too low to get at it unless i drive up on some wooden boards at the front...but mostly I jack up the front from the sides under the cross brace at the outermost bolts as I have two jacks and can raise the car evenly before placing jack stands.
The rear jacking point in the owners manual is the rear diff its easy and accessible so I always use it to get the rear end up.
NYG37S
General Tech Questions
Nov 20, 2017 05:42 PM
KnoxvilleG37
13
Jul 28, 2014 08:45 AM
Avalanche1521
May 27, 2011 10:00 PM
rks
25
Apr 26, 2011 04:36 PM
