Outside Temp Sensor
Old Jul 12, 2018 | 08:36 PM
Lickskillet's Avatar
Lickskillet
Outside Temp Sensor
I'm on my third G but this is is my first one to have readings on my outside temp read high. Anyone else see this and what can be done?
Old Jul 12, 2018 | 08:52 PM
Lego_Maniac's Avatar
Lego_Maniac
Mine reads ridiculously high. I assume it must be close to the ground such that it absorbs a ton of heat?
Old Jul 12, 2018 | 09:13 PM
iCrap's Avatar
iCrap
Mine always seems really high when I first start the car but after a few minutes of driving it always matches what my phone says the temp is outside. Maybe there is an offset in the settings?
Old Jul 12, 2018 | 10:27 PM
takemorepills's Avatar
takemorepills
The sensor is usually right behind the front grille on most Nissan/Infiniti, it will read high until you get moving as it is being warmed up by the radiator/condenser right behind it. Mine reads 3-4 too high until the car starts moving. Subarus have the same behaviour.
Old Jul 13, 2018 | 12:32 PM
VibrantSedan13's Avatar
VibrantSedan13
Mine seems very high as well. I replaced it with an oem one the other day, and that did not help. Oh well!!!
Old Jul 13, 2018 | 01:30 PM
Lickskillet
Its too bad someone doesnt make a plug and play relocate kit with an extended wire. I bet if you got the thing further away from the motor it would solve it
Old Jul 13, 2018 | 02:21 PM
jfridge92's Avatar
jfridge92
Mine reads about 15 degrees too high. It's hot in Florida, but it's not 115 out there lol!
Old Jul 13, 2018 | 02:25 PM
Lego_Maniac
I think 109 is the hottest I've seen.
We should hijack this into the post your min/max temp readings thread
Old Jul 27, 2018 | 09:39 PM
ross7778's Avatar
ross7778
Mine also reads high even after driving for awhile.
Old Jul 28, 2018 | 10:38 AM
Bostonreefer's Avatar
Bostonreefer
i have seen 109 this summer on like a 90 degree day.... so yeah. as others have said seems to eveb out longer i drive
Old Jul 28, 2018 | 11:09 AM
telcoman's Avatar
telcoman
As others have written the sensor will read high if you've been parked on a very hot day. After you drive a few minutes it will read the same as on my IPhone
Telcoman
Old Jul 28, 2018 | 01:12 PM
takemorepills
Mine read low the other day. It has been high 80's here, the nose of my car was in shade all day, and the temp sensor showed 65 for a very long time, even though it was 85. After about 20 minutes of driving it finally started climbing, but I think it was only at the low 70's by the end of my drive.
The temp sensor in my Titan is perfect, I don't think it is even affected by engine heat or idling.
Anyways, not a prob as usually the temp in my coupe is "good enough for gov't work"
Old Jul 28, 2018 | 05:15 PM
slartibartfast's Avatar
slartibartfast
Other than curiosity, why does anyone look at that sensor? I think I've checked mine three times in seven years.
Old Jul 29, 2018 | 12:10 PM
Lego_Maniac
It's between the speedo and tach, how can you not look at it and observe the temperature???
Old Jul 29, 2018 | 09:38 PM
slartibartfast
I keep the instantaneous fuel consumption chart in that space. It helps me keep my foot out of the throttle.
