2013 G37x Sedan Differential (Synthetic required?)
Old Jul 6, 2018 | 01:17 PM
puro's Avatar
puro
I picked up a 2013 g37xs a couple of weeks ago and I've been changing the fluids on it. Already did the atf and rear differential but while looking at how much I need for the front diff and transfer case I noticed on amsoils page it says "synthetic required" for the differential. I used valvoline 80w-90 because that was available at walmart. Do I need to use synthetic? I don't think the valvoline is. Thanks for the replies.
https://www.valvoline.com/our-produc...mance-gear-oil
Bonus pics of car..
https://imgur.com/a/0mUNpeU
Old Jul 6, 2018 | 02:51 PM
RMB5190's Avatar
RMB5190
While I'm not 100% sure, I'm going to say that as long as it's GL5 compliant you should be fine.
Good Looking G BTW
Old Jul 6, 2018 | 04:09 PM
slartibartfast's Avatar
slartibartfast
If you have the owner's manual, I do believe it lists the requirement on the fluids page(s).
Old Jul 10, 2018 | 11:29 PM
Cross country X's Avatar
Cross country X
I had my 12x sedan serviced at a Pacific Northwest Infiniti dealer a few months back hey used Mobil 1 gear lubes in the diffs and matic J in the transfer case (legit matic J, not S) fwiw. Not sure if synthetic is required or it was just been to pad their profits. . The car does feel quicker now, it has less rolling resistance when cruising and not under throttle, and better low rpm acceleration. The trans was also serviced at the same time, full fluid exchange with Valvoline Maxlife and 2500 miles later all seems well.
sharmelan
32
Jul 11, 2015 07:26 PM
grisensko
Jun 9, 2015 01:14 PM
Logan Magno
Mar 18, 2015 09:19 AM
DanG37
General Tech Questions
16
May 22, 2013 10:51 PM
Blummy
12
Apr 1, 2011 03:42 PM
