Help!
Old May 18, 2018 | 07:08 PM
Meez403's Avatar
Meez403
Help!
Hello guys as I was doing my transmission fluid drain I noticed that I had a leak from this one certain hose. as far as I can see it's somewhat connected to the power steering system? I checked all my fluids everything is fine, except the power steering fluid the I've topped off by a little bit. I was wondering what part this is? and if i could order this certain part only? could this be the power steering return hose?
Cheers folks,
Old May 22, 2018 | 01:23 PM
Surfnazi's Avatar
Surfnazi
Power steering uses auto trans fluid. Maybe on last oil change some oil spilled
Old May 22, 2018 | 03:30 PM
slartibartfast's Avatar
slartibartfast
Fluid on the outside of the line doesn't mean it's coming from inside the line. As Surfnazi wrote, it could be something spilled on the line while filling something else.
Old May 25, 2018 | 11:47 PM
Surfnazi's Avatar
Surfnazi
Spray brake cleaner on it and check in a day or 2
Uho001
Dec 18, 2009 08:49 PM
jnguyen
Oct 20, 2008 11:26 PM
