G37x Rattle/knocking sound
Old Nov 15, 2017 | 11:03 PM
Nick White's Avatar
Nick White
Having this issue with a rattle/knocking/pinging sound. been going on for a couple thousand miles, isn't getting any better or any worse. I've searched the forums but I can find one that's the same or with a solution. The rattle happens at idle to about 2200rpms and then it goes away. the video is pretty much right under the driver's side cat while I rev it to about 2k. The sound doesn't seem to be coming from under the hood, just under the engine, I can't even hear it under the hood. sounds like a popping/knocking sound. Does anyone have the same problem or know what it is and the solution? https://www.youtube.com/watch?v=5lAK...ature=youtu.be (wait until the car is revved a little in the video, you will hear the sound quite easily)
Old Jan 23, 2018 | 02:01 PM
Cicero55's Avatar
Cicero55
I'm having this exact same problem. It makes the noise just above 5000 RPM (IDLE) to 2,500 RPM....
I'm thinking that it's either the Torque Converter, Flex-Plate, or one of those other issues that people mentioned, such as the Cat making noise, or the heat shield being loose and rattling.
Any ideas?
Old Jan 29, 2018 | 04:53 PM
g37x2013's Avatar
g37x2013
I have a slight rattle on my 13 G37x too, low rpm- coming to stop, leaving stop or slow turning, thinking it relates to the exhaust. Maybe bad catalytic converter but also read it could be a rusted heat shield around the catalytic converter.
Old Mar 5, 2018 | 04:12 PM
Cicero55's Avatar
Cicero55
Well, I went to the my mechanic (who is a god-send) to get my oil changed, and he said that my BANK 2 Cat was shot. He is a god-send because he mentioned that our cars have 8 year, 80,000 mile Federal Emission Warranty; which, means that my cat is being replaced free of charge! Going in tomorrow at 8AM to have it replaced.
Old Mar 5, 2018 | 05:57 PM
slartibartfast's Avatar
slartibartfast
ALL automobiles sold on the US have that emissions warranty. Federal mandate.
Old Mar 5, 2018 | 06:02 PM
Cicero55's Avatar
Cicero55
You seem like a really fun person to be around.
Old Mar 5, 2018 | 06:06 PM
slartibartfast
I'm here all week. Be sure to tip your waitress.
Old Mar 6, 2018 | 10:39 AM
g37x2013's Avatar
g37x2013
BANK 2 on my G was shot too. At least you're within the range for warranty!
Old Mar 21, 2018 | 11:50 AM
G37xBrock's Avatar
G37xBrock
Any idea if an aftermarket exhaust would void this warranty?
Old Mar 21, 2018 | 12:35 PM
slartibartfast
It will not. Your dealer may try to blame it on some failure but you have the Magneson-Moss act to back you up. The dealer has to prove your mod caused the failure. The exhaust won't affect emissions.
Old Mar 21, 2018 | 04:45 PM
G37xBrock's Avatar
G37xBrock
Good to know. Thanks!
