Air Bag wires under driver seat, little springs
Old Apr 5, 2017 | 10:37 AM
27Fountain's Avatar
27Fountain
When reinstalling driver seat the air bag wires, I believe two little springs came out of a yellow connector. I reconnected however the Air Bag light is blinking now. SO I can reassemble correctly, does anyone know what those little springs or connector is called or part#
Thank you
Will
Old Apr 6, 2017 | 01:40 AM
crookncastle's Avatar
crookncastle
not familiar with what you are referring to. take a pic of the springs and the connector you are referring to. are you sure the air bag light wasn't triggered as a result of the ignition being in the "ON" position when you disconnected the connector?
Old Apr 7, 2017 | 11:22 AM
27Fountain's Avatar
27Fountain
Ok, pulled the seat out, hell now I can't figure out the connector the springs went in. To top it off I lost one of the springs. To be honest the airbag light and springs in connector may not even be related? The springs are small, almost identical to the spring in a writing pen.
The Air Bag light blinks one long, then five short. When I rebuilt car I had to replace the seat air bag and curtain air bag. I may just order a code reader to save time???
Old Apr 7, 2017 | 11:53 AM
27Fountain's Avatar
27Fountain
Holy crap, I finally figured it out, it is the connector for the seat air bag (under seat). Yellow connector has a white slide on the top, the springs are inside the white piece allowing the white part to slide. Not sure the function, however I will fix.
