Blinker noise and beeps
Old Jul 16, 2016 | 11:55 AM
MarshallFriday's Avatar
MarshallFriday
I've noticed recently that the beeps that happen when you get in or out of the car have been muted occasionally. Also, when I turned my blinkers on today, I couldn't hear them inside the car. Is there a fuse that controls the volume of those two functions? Anyone else experienced this? 2008 G37S with 121K miles.
Old Jul 16, 2016 | 12:45 PM
bigmike35nj's Avatar
bigmike35nj
I swear I just started noticing the same thing within the last 2 weeks. Some time I hear it and sometimes I don't.
Old Sep 2, 2016 | 03:11 PM
dmg6768's Avatar
dmg6768
I had that same problem.
Got in the car, turned it on, turned the blinker on, then the headlight on, turned blinker off, then headlight off. That seemed to reset it.
It was that or some variation of that.
Old May 31, 2018 | 10:57 AM
dmg6768's Avatar
dmg6768
Turns out I've been dealing with this problem for the last two years. It wasn't some reset procedure that needed to be done. I had to actually replace the speaker that was attached to the instrument cluster board.
I had to remove the instrument cluster, desolder the old speaker and solder in a new one. Not terribly difficult, but I didn't readjust my gas gauge meter properly so it looks like I 've got 1/8 tank more gas than I really do.
Old May 31, 2018 | 02:27 PM
slartibartfast's Avatar
slartibartfast
And here I was going to suggest you check your blinker fluid.
jk315
May 7, 2016 04:21 PM
Envee
Mar 30, 2016 10:28 PM
armino41
Mar 30, 2016 01:25 PM
Trolololol
Mar 29, 2016 03:09 PM
shujz
Mar 17, 2016 05:03 PM
