Please help :(
Please help :(
Yesterday first real hot day of the year 90+ degrees ...I thought I felt my acceleration response really bog down . I was trouble shooting and testing the clutch and it seemed fine . All of a sudden my clutch got stuck half way and I had to physically use my foot to bring it up but the lack of pressure behind my clutch got worse and worse . I went home decided to go home before I ended the day I checked my reservoir and it was dark so I decided to go the easy way siphon it out the stop and add dot 4 higher temp to make it lighter .. Well it worked like a charm and it got smoother and fixed the problem (there was still a squeak sounded like the assembly though) next morning (today) I go check and again stuck . I drive it for 5 mins half way I pump it a few times and now it's depressed completely and won't go into gear !
Air in lines ? Slave cylinder or master cylinder ? Both ?
I would bleed mine old car everytime i refilled from empty..
Try it out..
Also check the pedal itself and make sure there is free movement under the dash (where its mounted)..
Miles? How do you drive the car?
Try it out..
if the fluid is dark my experience is the mc is wearing out. may still work but definitely causing the dark fluid. if you ever change it when you remove the hose ull see all rusty looking corrosion on the nipple part
Brian Londry
20
Apr 17, 2022 11:49 PM
