Changing battery
Old May 19, 2016 | 09:32 AM
tchoke's Avatar
tchoke
Changing battery
Have had to get boosted on my 2010 original battery a few times now and decided to change this morning
However when I disconnected the positive side I noticed a tiny bracket chewed up... I didn't think much of it till I saw a black wire that looks like it goes to nowhere
Anyone know what this could be<br/>Owned the car for 3 yrs and i dont have anything aftermarket that i installed<br/>
Old May 19, 2016 | 12:50 PM
SonicVQ's Avatar
SonicVQ
Someone before you added something.
Why not follow the wire and see where it goes?
Old May 19, 2016 | 06:19 PM
telcoman's Avatar
telcoman
If it is coming from the neg battery terminal it is probably a ground wire
Telcoman
Old May 19, 2016 | 07:21 PM
Kris9884's Avatar
Kris9884
From the picture its hard to tell but if that's the same wire that's going back towards the driver side under that vent then yeah, probably an old set of fog lights or even a super misplaced ground but I highly doubt that. As stated, the only way to know is to follow it..
Old May 19, 2016 | 09:36 PM
JSolo's Avatar
JSolo
Just say no!!!!!
Put a meter on it and ground, do you get voltage? If no, change to continuity mode, do you get a sound or 0Ω of resistance? If so it's a ground.
Does everything work on the car? If yes, then just disregard it.
Old Jun 4, 2016 | 02:01 AM
Juelz86g37s2012's Avatar
Juelz86g37s2012
Check ground just because you need to get jump starts
jcm707
May 12, 2016 03:24 PM
McStealth
12
May 5, 2016 07:56 PM
Turbo68
May 2, 2016 05:22 PM
rstocker87
Apr 26, 2016 01:40 PM
Jharris93
Apr 25, 2016 11:54 AM
