Trunk Open Alert Question
Old Apr 10, 2016 | 12:05 AM
tite_tite's Avatar
tite_tite
I just got my rear end fixed after accident...
Can ya tell me if ur car has an alert when u hit trunk release switch under the steering wheel?? The alert is by the speedometer.
It will only alert me if it is fully up open
2010 g37 sedan
Old Apr 10, 2016 | 10:17 AM
Thirty_Seven's Avatar
Thirty_Seven
It won't alert you until you actually open it. When you hit the button, it puts it into like a semi-locked position, another few inches open is when the light comes on. If you hit the button and drive around, the light will flicker on and off as the trunk bounces up and down.
Old Apr 11, 2016 | 11:34 PM
tite_tite's Avatar
tite_tite
Cool. Thanks for the info.
Hmmm... i thought it would alert me before when i had push the trunk switch from the inside. guess my memory is shot
thanks again.
Old Apr 13, 2016 | 08:19 PM
jakebeefsteak's Avatar
jakebeefsteak
Sounds like there is a sensor/switch in the system. Mine gives the dash alert as soon as the trunk is popped via dash switch or key fob. Maybe others will chime in but it sounds like your memory serves you correct. Mine is a '12 model.
Old Apr 13, 2016 | 11:06 PM
tite_tite's Avatar
tite_tite
thanks for the confirmation. yeah, i thought it would alert me once the switch was press. i think mines is not lifting up or high enough but at least it is open.
Old Apr 28, 2016 | 10:18 AM
tite_tite's Avatar
tite_tite
So had some time today & took car back to body shop that did the repair. They adjusted the latch thingy & all is working normal. Trunk alert comes on when pressing trunk release switch + trunk is easier to open since it is lifted up a lil higher.
Thanks all for ur input
Old Apr 29, 2016 | 09:53 AM
Kris9884's Avatar
Kris9884
Good to hear, mine alerts me if its open at all.
Old Apr 29, 2016 | 01:32 PM
Mine as well... once I press the trunk open button the alert comes on right away.
Raegenjay
12
Apr 28, 2016 11:26 AM
Nathan Benoit
Apr 5, 2016 12:54 PM
Ryne
Apr 1, 2016 10:44 AM
Mar 25, 2016 02:58 PM
rsingerG37
Mar 22, 2016 01:49 AM
